    M5Stack-MegaChess - Any update?
    4 Posts 3 Posters 9.5k Views 1 Watching
    • I Offline
      iPodLux
      Hi
      Has anyone tried to compile in Arduino cc 1.8.xx the chess example?
      I've just discovered it but it seems it doesn't compile with a list of errors ...
      Any suggestions?
      https://github.com/m4k3r-net/M5Stack-MegaChess
      • lukasmaximusL Offline
        Could you list the errors here, and then we will have a better idea of what the problem might be. I assume you already installed the esp32 board manager files, preferences.h is included with them
        • I Offline
          iPodLux
          No prob at all.
          I made sure the esp32 is installed and Arduino points to the right directory. After that this is the outcome:
          Arduino: 1.8.12 (Windows 10), Board: "M5Stack-Core-ESP32, QIO, 80MHz, Default, 921600, None"
          C:\Users\planv\Documents\Arduino\arduinomegachess_for_m5stack\arduinomegachess_for_m5stack.ino: In function 'void show_cont(int, int)':
          arduinomegachess_for_m5stack:764:61: error: invalid types 'const uint8_t [6][72] {aka const unsigned char [6][72]}[__gnu_cxx::__enable_if<true, double>::__type {aka double}]' for array subscript
           drawBitmap(ii*28+10, jj*28+3,&fig_cont[abs(pole[j][i])-1][0], 24, 24,color);
          C:\Users\planv\Documents\Arduino\arduinomegachess_for_m5stack\arduinomegachess_for_m5stack.ino: In function 'void show_fig(int, int)':
          arduinomegachess_for_m5stack:855:56: error: invalid types 'const uint8_t [6][72] {aka const unsigned char [6][72]}[__gnu_cxx::__enable_if<true, double>::__type {aka double}]' for array subscript
           drawBitmap(ii*28+10, jj*28+3,&fig[abs(pole[j][i])-1][0], 24, 24,color);
          arduinomegachess_for_m5stack:856:61: error: invalid types 'const uint8_t [6][72] {aka const unsigned char [6][72]}[__gnu_cxx::__enable_if<true, double>::__type {aka double}]' for array subscript
           drawBitmap(ii*28+10, jj*28+3,&fig_cont[abs(pole[j][i])-1][0], 24, 24,color_cont);
          C:\Users\planv\Documents\Arduino\arduinomegachess_for_m5stack\arduinomegachess_for_m5stack.ino: In function 'String str_step(int)':
          arduinomegachess_for_m5stack:930:60: error: invalid types 'const char [8][__gnu_cxx::__enable_if<true, double>::__type {aka double}]' for array subscript
           if (abs(steps[i].fig1)>1) s=fig_symb[abs(steps[i].fig1)];
          arduinomegachess_for_m5stack:938:64: error: invalid types 'const char [8][__gnu_cxx::__enable_if<true, double>::__type {aka double}]' for array subscript
             if (abs(steps[i].fig2)>1) s=s+fig_symb[abs(steps[i].fig2)];
          Used: C:\Users\planv\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\SD
          Not used: C:\Program Files (x86)\Arduino\libraries\SD
          Multiple libraries were found for "WiFiClient.h"
          Used: C:\Users\planv\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
          Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
          exit status 1
          • ChrisWRC Offline
            ChrisWR
            https://drive.google.com/file/d/1Gx1Nh-VmZIU_m0ZbCK0UWXfuLv6L06Tq/view?usp=sharing
