    OMG, serial console!
    Micropython
    11.4k
    • D
      dclaar
      Maybe everyone else knows this, but I just discovered that you can connect to the M5stickC over the serial connection and get a python prompt!
      >plink -serial \\.\COM4 -sercfg 115200,8,1,n,n
      [0;32mI (8) boot: ESP-IDF v3.3-beta1-696-gc4c54ce07 2nd stage bootloader
      [0;32mI (9) boot: compile time 19:37:28
      Connected. Network config: ...
        File "main.py", line 130, in <module>
        File "main.py", line 128, in <module>
        File "main.py", line 96, in GetAQI
      NameError: name 'wait_ms' isn't defined
      MicroPython v1.11-321-gac7da0a70-dirty on 2020-02-25; ESP32 module with ESP32
        ajb2k3 @dclaar
        @dclaar Welcome to the Micropython world.
        This feature has been known and doumented several times, I think @lukasmaximus made a video for it.
        BTW if you use the new beta firmware (1.5.0) use Mu as the IDE as it make coding so much easer.
        BTW2: you can also access it in vstudio.
        • K
          kylebuttress
          Hi
          I have found Thonny a nice editor as well, it lets you interact with the shell and transfer files.
          https://thonny.org
          • D
            dclaar @ajb2k3
            @ajb2k3 Thanks! I figured that somebody knew about it, but I had searched for various terms like serial, console, debug, etc, and didn't find it, so I thought I'd post this to perhaps help others find it. :)
            • D
              dclaar
              Thanks for the IDE recommendations.
              I like vstudio because I can load the vim extension and pretend that I'm using a terminal. :)
              (Shoveling python is my day job, so I don't tend to use an ide unless I have to).
                The serial console access is known as REPL.
                If you didn't know about REPL then it is no wonder that you are surprised.
