    Code only works from Visual Studio
    Micropython
    micropython
    14.5k
    • D
      dclaar
      I have this code:
      def main():
        purple_air = PurpleAir()
        # Reset orientation when A pushed. End test if testing.
        btnA.wasPressed(purple_air.SetOrientation)
        btnB.wasPressed(purple_air.Testing)
        wifi_try_count = 0
        while True:  while True:
          if not (wifiCfg.wlan_sta.isconnected()):
            wifi_try_count += 1
            purple_air.ShowError(
              'No WiFi ({:d})'.format(wifi_try_count))
            wifiCfg.doConnect('FBI', 'CIA')
            purple_air.ShowError('WiFi connected')
          else:
            purple_air.ShowError('Trying')
            try:
              purple_air.GetAQI()
            except Error as e:
              purple_air.ShowError(e)
          purple_air.ShowError('Waiting')
          wait_ms(1)
          purple_air.ShowError('Done')
      When I run from Visual Studio, it connects to WiFi, prints WiFi Connected, Waiting, Done, Trying all in a row.
      When I disconnect it, choose it from the App screen, it will stop at WiFi Connected. If I yank out the entire else clause, then it will stop at Waiting. In either case, exactly 1 print statement after connecting to WiFi.
      It's not actually completely dead: Pressing the A or B buttons execute the callbacks as expected.
      But I can't figure out why it reacts differently connected vs. unconnected!
      Any ideas?
      • D
        dclaar
        OK, I have no idea why, but taking out the else: works. (I took out main() first, and that didn't help, but I didn't put it back in once things worked). I haven't run it for a long time, so it might still hang, but initial indications are promising!
        while True:
            wifi_try_count += 1
            wifiCfg.doConnect('Mi5', 'double07')
          try:
            purple_air.GetAQI()
          except Error as e:
          wait_ms(1)
        • D
          dclaar
          Nope, spoke too soon. It just takes longer to hang. :(
          • D
            dclaar
            I found out that you can actually get a serial console, and it says:
              File "main.py", line 130, in <module>
              File "main.py", line 128, in <module>
              File "main.py", line 96, in GetAQI
            NameError: name 'wait_ms' isn't defined
            Don't ask me why it works when connected to the laptop, though!
            Serves me right for trying to limit the imports. :)
            • lukasmaximusL
              wait_ms is part of the uiflow class, did you import it at the start of your program?
              • D
                dclaar
                I was trying to be "more pythonic" and not import *, i.e.
                from m5stack import lcd
                It didn't occur to me that it was in uiflow!
                I've gone back to importing everything. :)
                • R
                  robalstona
                  I noticed that some development environments use REPL when transferring files and running. And by the way, they silently import various system libraries / modules. Eg uPyCraft imports os library to display a list of files. By the way, the wait_ms () can be imported from the time library
                  • D
                    dclaar
                    Given that I can now see the console, I determined that it throws OSError if the http GET fails. Which is a weird error to throw, but OK. So I put that in my except: clause, and it's humming away!
