    How to avoid text flicker ?
    5 Posts 4 Posters 19.9k Views 3 Watching
      DrWino
      I am writing text to the same location with updated values. I get the text superimposed on the old text. i use a space, the reset the setCursor, then write the new text. But I get flicker - How to avoid this ? Also if you make a filled rectangle and then write text on it - the whole thing flickers like mad.
        Sergey_Urusov
        Just save previous displayed value in global variable, before display compare with saved, and display only if they differs.
        • reaper7R Offline
          reaper7
          this is a good option as @Sergey_Urusov wrote,
          instead rectangle you can also overwrite old value with inverted color
          something like this:
          #include <M5Stack.h>
            M5.Lcd.fillScreen(BLACK);
            M5.Lcd.setTextSize(7);
          void loop(){
            static int rndold = -1;
            int rnd = random(0, 100);
            if (rnd != rndold) {
              //overwrite old value with inverted color
              M5.Lcd.setCursor(40, 40);
              M5.Lcd.setTextColor(BLACK);
              M5.Lcd.printf("%02d", rndold);
              //write new value
              M5.Lcd.setTextColor(WHITE);
              M5.Lcd.printf("%02d", rnd);
              rndold = rnd;
              delay(250);
          • dasloloD Offline
            daslolo
            You can try PrintToSprite in the TFT_eSPI library. https://github.com/Bodmer/TFT_eSPI/issues/116
            • dasloloD Offline
              daslolo
              Here is the solution. https://github.com/Bodmer/TFT_eSPI/tree/master/examples/Sprite/Sprite_scroll
              Thanks to @Calin
