    Looking for the Base Firmware for Unit-V
    5 Posts 4 Posters 10.1k Views 1 Watching
      kylebuttress
      I'm looking for the Base Firmware for Unit-V, I was experimenting and have made a mistake with the unit-v and would like to know where I can get the base firmware so I can reflash to its default.
        http://community.m5stack.com/topic/1872/m5stickv-firmware_v5-1-1_beta
          kylebuttress
          Is there a correct way to flash the firmware using esptool i'm using esptool.py --chip esp32 --port /dev/tty.SLAB_USBtoUART --baud 115200 write_flash -z 0x1000 M5StickV_Firmware_v5.1.1_beta.kfpkg becuase even though it seems to flash I cannot connect with Maixpy i'm getting the following Connect fail, board ide mode no ack
          Any tips would be appreciated.
          thanks Kyle
            Thrasher
            Esptool can't flash it, its not an esp chip
            You need stickV burner from guides section
            https://docs.m5stack.com/#/en/core/m5stickv
            EasyLoader is
            • m5stackM Offline
              the M5StickV/UnitV burn firmware tutorial
              https://docs.m5stack.com/#/en/quick_start/m5stickv/m5stickv_quick_start
