UIFlow 1.5.0
Ver 1.5.0. time : 2020.04.10
UpdateLog:-
- Speed ​​up the boot and Improve file writing speed, download time is greatly reduced
- When the program is executed, it will be written to the temp. py file
- Update UI interface, modify settings interface and APP interface
- The UIFLOW setting is migrated to the very end of FLASH, the average user will not affect the UIFLOW setting and WIFI saving without erasing FLASH
- Set the option to add skip 1s waiting time
- Set add random APIKEY option
- Add setting interface to Wi-Fi connection interface to enter the entrance
- APIKEY connection interface to add settings and APP-list interface to enter the entrance
- Update ESP-IDF dependency to 3.3, fully migrate to micropython mainline (save 500KB Flash)
ps:
- For the time being, UIFlow v1.5.0 is only compatible with M5Core. The firmware of other hosts such as M5StickC will be released later.
- UIFlow v1.5.0 unsupport Remote function.
use M5Burner to upgrade the firmware.
euwwww....that seems the worst firmware I have ever seen.
Nearly nothing does work.
Has anyone tested it?I use UIFlow 1.0.8.1 Desktop
It is not only the Firmware - the UIFlow 1.0.8.1 is not working too - I cannot connect to my Core, only when I had connected with an older UIFlow before - crazy
When I try any demo, it runs only for a second an the stops
I'd like to go to the older tools -
@m5stickfreakler said in UIFlow 1.5.0:
The desktop version is too old to run with the new firmware, please use the online version to get the latest update functions.
When Version 2 is released the desktop version should contain the same updates as the online version.
@ajb2k3 When might we expect version 2.0?
@conrad I don't know, I am only getting "it will be fixed in version 2.0"
@m5stack Can't select between core, StickC and Atom using Chrome Version 81.0.4044.113 (Official Build) (64-bit) on OSX 10.14.2
