    m5burner error ImportError: No module named serial.tools.list_ports
    SOFTWARE
    5
    10
    17.3k
    • J
      Jerman
      i got this error:
      but i have downloaded pyserial
      what happened?
      • m5stackM
        m5stack @Jerman
        @jerman what PC system are you used?
        • J
          Jerman
          Linux
          • m5stackM
            could you take a screenshot ? our linux machine test the software totally normal.
            • J
              Jerman @m5stack
                Your python install is missing some tools needed for M5Burner to run.
                Please check out this link https://github.com/espressif/esptool/issues/350
                • lukasmaximusL
                  There are some certain processes you need to make any esp32 device work on linux, such as adding the user to the dialout group, usb permissions etc, this video expains about it https://www.youtube.com/watch?v=ZZdTl0400uM
                  • G
                    GertKok
                    Hi Guys, had the same issue. Running PopOS (Ubuntu/Debian) Did all that was said here and the video. No Joy. Tried V1.4.5 instead of V1.4.5.1 and my M5Stack Gray flashed. Could it be an issue with 1.4.5.1?
                    • J
                      Jerman
                      I have found the solution!
                      do sudo su first
                      the pip install pyserial
                      or
                      pip3 install pyserial
                        Opps, yes, Python need to be installed as super user (su) in order to work properly.
