    How to use Unicode.
    General
    7
    13.7k
    • P
      peter153
      @m5stack
      Github Display_Unicode example has an error.
      ***CUF_24px.h:156463:7: error: 'EncodeRange' does not name a type
      const EncodeRange CUF_24pxEncodeRange[] PROGMEM = {***
      • m5stackM
        Pls modify <m5stack path>/src/utility/In_eSPI_Setup.h, At the end of the file add "#define USE_M5_FONT_CREATOR"
        you could check the note in the code head
        • P
          peter153
          Add the In_eSPI_Setup.h file to the aduino IDE project, and #define.. Does this mean that the annotation should be lifted?
          • P
            peter153
            same error.
            ![alt text](0_1584752127867_examplUniicode.JPG image url)
            • T
              tehnolog
              I have the same problem with "Display_Unicode" example. I added "#define USE_M5_FONT_CREATOR", but now I have the error: "Sketch to big"
              Please, help me. I need Unicode characters.
              • T
                tehnolog @tehnolog
                @tehnolog I solved my problem
                • L
                  Lewis-H
                  Unicode characters can then be entered by holding down Alt , and typing + on the numeric keypad, followed by the hexadecimal code – using the numeric keypad for digits from 0 to 9 and letter keys for A to F – and then releasing Alt .
