    UnitV Barcode scanning
    Units
    6.0k
    • P
      puijkh
      Hi, I am trying to scan a barcode with my UnitV, but i was not successfull.
      I am using the MaixPy IDE have uodated to the latest fw and use this code:
      img = sensor.snapshot()
      res = img.find_barcodes()
      Unfortunately there is never any info in the returned res. I can see the barcode in the MaixPy IDE. I also tried qr codes with res = img.find_qrcodes(), but that also does not work.
      Any idea's on how to get the scanning working?
      hagueH 1 Reply Last reply Reply Quote 0
      • hagueH
        hague @puijkh
        @puijkh Same for me with april tags. Did you found a solution?
        • hagueH
          hague
          Hi, Maybe flipping the sensor image will fix this:
          sensor.set_vflip(1)
          This was the solution for my problem with april tags and QR-Codes.
