    recover m5 file from m5stack
    5 Posts 4 Posters 7.9k Views 2 Watching
      rebirth
      Last year I made an m5 project, put it on my m5stack, and saved the file on my pc.
      2 months ago, my hard drive from my pc crashed, so I lost the m5 file I saved on it.
      Now I wanted to make some adjustments to my file, but I don't have the source file anymore.
      Is there any way to get the file from my m5stack to open in UIFlow, so I can make the changes and redownload it to my m5stack?
        Thrasher
        You can try to connect to m5 with vs code, browse filesytem, find and copy your code file to hard drive
        • world101W Offline
          world101
          Assuming you were running a recent version of uiFlow firmware on your device, another way is with ampy.
          ampy --port=/dev/tty.SLAB_USBtoUART --baud=115200 ls /flash/blocks
          ampy --port=/dev/tty.SLAB_USBtoUART --baud=115200 get /flash/blocks/{file}.m5f ~/Downloads/{file}.m5f
          Open the .m5f file into uiFlow. Or you could also check the /flash/apps directory and obtain the .py files, but you will not be able to load that directly into uiFlow and edit the blocks.
          • m5stackM Offline
            替代文字
              rebirth @m5stack
              @m5stack That worked! Thank you!
