    UIFlow 1.4.5
    Official Updates
    14
    31
    120.8k
    • m5stackM
      Ver 1.4.5. time : 2020.02.26
      UpdateLog:
      firmware:
      • 1.Add: Burner wifi set.
      • 2.Add: ATOM support.
      web:
      • 1.Add Atom-Lite, Atom-Matrix support.
      • 2: Fixed some bugs.
      ps: The Windows 10 version is currently available. MacOS and Linux versions will be released later.
      M5Burner, please click the settings button in the upper left, and then click the version update,then download UIFlow 1.4.5 .
      UIFlow 1.4.5 supports firmware configuration WIFI information.
      ATOM API key can be seen through web configuration page or serial port tool
      ATOM UIFlow Tutorial:https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start
      替代文字
      替代文字
      • T
        Thrasher
        Thanks, let's give some support to team as they keep working during tought times!
          Thanks but whats the address for the ATom?
            UIFlow is broken, the UI interface blocks menu is missing for StickC and Core.
            Well that is interesting, if you switch to atom then switch back the menu vanishes but if you reload the page as a stick, the menu reappears.
            • m5stackM
              m5stack @ajb2k3
              @ajb2k3 I has already test . but nothing happens. could you clean your website cookie then try again?
              • SkinkS
                Skink
                I burned the Atom Matrix with software 1.4.5, it works with SSID and password. And I can also set it to wifi and see that it is logged on the router.
                But where can I find the API key to program online!?
                • R
                  robalstona
                  Connect the atom to the computer and connect to it with the terminal program, system information along with the API key are displayed during startup. The second option is to keep the matrix button pressed while starting until the colors change pulsatingly. And release it when it is pink / purple. then the atom will launch its access point. Connect to his network via 192.168.4.1 address and then in the browser you will see the API key and you will be able to choose the network to which you will connect.
                  SkinkS 1 Reply Last reply Reply Quote 1
                  • lukasmaximusL
                    Start a terminal session with your Atom I usually use
                    screen "device port" 115200
                    reboot your stick and the API key will appear in the boot message
                    • lukasmaximusL
                      @robalstona beat me to it, nice tip on the button hold
                      • R
                        robalstona
                        there are other modes depending on with color you relase button while booting. App mode (run main.py), uiflow web, uiflow usb, and web config. You can see colors and modes in boot.py
                        • J
                          jpilarski
                          I love seeing the graphic icons of the two new boards they look really cool in the simulator. I am sure you are already working on this but there needs to be a way, after selecting the leds in the simulator, to save a page of the toggled leds for the atom and then play back or trigger those pages. I picture something like the emoji interface you had in previous releases would be helpful to bring back since it had multipage options for crerating animations. alt text
                          I imagine much of the code used used on the 5x5 microbit screen would be helpful if ported to UIflow. Things like the various 5x5 fonts they have avaiable as well as the various scrolling routines https://makecode.microbit.org/#editor FONTS. I know this is just the beginning and it already looks great but I thought I would state the obvious benefit of adding in some of this capability in future releases. thanks for the new release it's always fun to see what new tools you've made for us.
                            ajb2k3 @jpilarski
                            @jpilarski agreed. I asked about something like this for the neoflash and NeoFlashC
                            • M5StickFreaklerM
                              M5StickFreakler
                              Is there also a ne UiFlow Version that support ATOM? My Version is 1.0.7 and does not allow to program ATOM
                                ajb2k3 @M5StickFreakler
                                @m5stickfreakler You mean offline version?
                                • M5StickFreaklerM
                                  M5StickFreakler @ajb2k3
                                  @ajb2k3 said in UIFlow 1.4.5:
                                  Yes I mean offline version :-)
                                  • MatiM
                                    Mati
                                    hmm small bug with Button ? At Atom Matrix
                                    There is only one button :D
                                    • m5stackM
                                      m5stack @Mati
                                      @mati thanks your feedback , we will fix it as soon as possible
                                      • SkinkS
                                        Skink @robalstona
                                        @robalstona said in UIFlow 1.4.5:
                                        Thank you it works :-)
                                        Greetings skink
                                          @m5stack Can you get the RGB LED blocks removed from the Hardware section of blocks and move the to the Base/Module section please?
                                          • I
                                            illusion
                                            why would people above say that pink/purple is the config mode? after flashing 1.4.5 for me the yellow mode is the config mode...
                                            after flashing 1.4.5 neither online (breathing green mode) nor offline ide works for me... absolutely not...
                                            usb mode (blue light) does nothing for me...
                                            i could only flash firmware and that's about it... pretty useless, no? still a facepalm for me at this point...
                                            and btw what is "app run mode"?
