    Integrate into a "dock" or bench?
    General
    8.4k
    • technerdchrisT
      technerdchris
      Hi, I just learned of the m5 stack system and am excited because it seems I won't need to build and program the UI like I have for prior projects. Just a couple buttons can add days to a prototype!
      I envision a testing bench with a core, face, and joystick module.
      • Is it possible to also add the USB module with core and face?
      • Does it go above the face and below the core?
      • USB module also has general IO pins? (I may interface with a stepper motor driver, etc)
      This bench it would affix to, I will create and it will hold the face and supply power, too. I have built test benches with chipKIT and ESP32 and wish I have used m5 Stack, which looks like will be my favorite going forward.
      Thanks!
      Chris
      • m5stackM
        Yes. You can stack "FACES Bottom + FACSE joystick panel + USB module + Core". The USB module has many IO pins. You can use them to program high or low digital signals. But you are not sure if it has the ability to drive a stepper motor. You can refer to its data sheet for this.
        USB Module MAX3421E- datasheet link: https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/docs/datasheet/module/MAX3421E_en.pdf
        technerdchrisT 1 Reply Last reply Reply Quote 0
        • technerdchrisT
          technerdchris @m5stack
          @m5stack does the USB module go on top of the FACES and under the Core?
          Yes, I would use an intermediate driver for the stepper itself and use the MCU + USB module to send signals. I mostly assume MCU pins do not do any work beyond to send/receive signals. ESP project above uses 3.3V relay to switch 12VDC. The chipKIT project referenced above uses Sparkfun Easy Driver product. Another application with a more hefty stepper uses "Rugger Circuits" designed Rugged Motor Driver shield.
          Thanks,
          Chris
          • m5stackM
            m5stack @technerdchris
            @technerdchris yes , USB module go on top of the FACES and under the Core , then stack they together
