    Description M5Stack 6060-PUSH
    13 Posts 4 Posters 24.9k Views 1 Watching
      sheepDog
      @m5stack
      I know the link at your answer. At the linked webpage is no information about pinout or details of the commands! Can you help me?
      ajb2k3A m5stackM 2 Replies Last reply Reply Quote 0
        ajb2k3 @sheepDog
        @sheepdog said in Description M5Stack 6060-PUSH:
        @m5stack
        The 6060 Push is not well documented.
        Have you seen this page?
        https://docs.m5stack.com/#/en/uiflow/RS485
        • m5stackM Offline
          m5stack @sheepDog
          @sheepdog actually you just need look at the Product Photo . you can found the commands.
            sheepDog @ajb2k3
            @ajb2k3 Thank you for the new link, I didn't know this page
            @m5stack I saw the commands at the product photo, but this didn't answer my questions:
            1. Where is which Pin (G = GND , V = Voltage, RS485-A, RS485-B)
            2. Which voltage is correct? 24V?
            3. What is the answer of the commands, for example -ID<number>I\r\n - Read busy -
              I share the opinion that the component is currently not well documented. Sorry.
              ajb2k3 @sheepDog
              @sheepdog some more information
              Pins are show here.
              alt text
              alt text
              Voltage is 12 to 24 vdc.
              https://docs.m5stack.com/#/en/accessory/485t
              https://docs.m5stack.com/#/en/base/plc_base
              https://docs.m5stack.com/#/en/app/ac_socket
                ajb2k3 @ajb2k3
                @m5stack In the descriptions of RS485 I see mention of a 100 (120 ohm in the picture above) ohm termination resistor. Is this in each of the devices or is it needed?
                • O Offline
                  option
                  Use one 120ohm resistor in each end of the bus.
                  If unclear try google for "rs485 termination"
                    ajb2k3 @option
                    @option said in Description M5Stack 6060-PUSH:
                    That's what caused me to ask!
                    @option I just need to check with m5stack before recording in my book.
                      sheepDog
                      @ajb2k3 and @option Thank you for your help.
                      • m5stackM Offline
                        m5stack @ajb2k3
                        @ajb2k3 Usually not required, it is recommended to add it for long distance communication
                          ajb2k3 @m5stack
                          @m5stack Thanks.
