    project error at: https://github.com/0x1abin/M5Stack_TinyBasicPlus
    Scheduled Pinned Locked Moved FACES Kit
    10 Posts 3 Posters 23.0k Views 1 Watching
    • sysdl132S Offline
      sysdl132
      When I compile the files on this file,often error:... is not declared in this scope...
      For Atom:115200/230400/921600
      • sysdl132S Offline
        sysdl132
        Anyone can fix it?
        • sysdl132S Offline
          sysdl132
          Somebody?
            dda
            A screenshot or full text of the error would be helpful...
            • sysdl132S Offline
              sysdl132
              Error:
              Arduino:1.8.9 (Windows 7), 开发板:"M5Stack-Core-ESP32, QIO, 80MHz, No OTA (Large APP), 921600, None"
              C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Administrator\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Administrator\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Administrator\Documents\Arduino\libraries -fqbn=esp32:esp32:m5stack-core-esp32:FlashMode=qio,FlashFreq=80,PartitionScheme=no_ota,UploadSpeed=921600,DebugLevel=none -ide-version=10809 -build-path
              (many words)
              正在编译项目...
              "C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/config" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/app_trace" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/app_update" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/asio" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/bootloader_support" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/bt" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/coap" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/console" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/driver" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp-tls" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp32" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp_adc_cal" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp_event" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp_http_client" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp_http_server" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp_https_ota" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp_ringbuf" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/ethernet" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/expat" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/fatfs" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/freemodbus" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/freertos" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/heap" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/idf_test" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/jsmn" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/json" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/libsodium" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/log" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/lwip" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/mbedtls" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/mdns" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/micro-ecc" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/mqtt" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/newlib" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/nghttp" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/nvs_flash" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/openssl" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/protobuf-c" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/protocomm" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/pthread" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/sdmmc" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/smartconfig_ack" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/soc" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/spi_flash" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/spiffs" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/tcp_transport" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/tcpip_adapter" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/ulp" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/vfs" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/wear_levelling" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/wifi_provisioning" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/wpa_supplicant" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/xtensa-debug-module" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp32-camera" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/esp-face" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2/tools/sdk/include/fb_gfx" -std=gnu++11 -fno-exceptions -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10809 -DARDUINO_M5Stack_Core_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="M5Stack_Core_ESP32"" "-DARDUINO_VARIANT="m5stack_core_esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\cores\esp32" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\variants\m5stack_core_esp32" "-IC:\Users\Administrator\Documents\Arduino\libraries\M5Stack\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPI\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\FS\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SD\src" "-IC:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPIFFS\src" "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_883032\sketch\M5Stack_TinyBasicPlus.ino.cpp" -o "C:\Users\ADMINI~1\AppData\Local\Temp\arduino_build_883032\sketch\M5Stack_TinyBasicPlus.ino.cpp.o"
              C:\Users\Administrator\Desktop\M5Stack_TinyBasicPlus-master\M5Stack_TinyBasicPlus\M5Stack_TinyBasicPlus.ino: In function 'void setup()':
              M5Stack_TinyBasicPlus:2029:40: error: 'printString' was not declared in this scope
              printString((unsigned char*)initLogok);
              C:\Users\Administrator\Desktop\M5Stack_TinyBasicPlus-master\M5Stack_TinyBasicPlus\M5Stack_TinyBasicPlus.ino: In function 'void outchar(unsigned char)':
              M5Stack_TinyBasicPlus:2182:18: error: 'termPutchar' was not declared in this scope
               termPutchar(c);
              使用 0.2.8 版本的库 M5Stack 在文件夹: C:\Users\Administrator\Documents\Arduino\libraries\M5Stack
              使用 1.0.1 版本的库 Wire 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\Wire
              使用 1.0 版本的库 SPI 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPI
              使用 1.0 版本的库 FS 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\FS
              使用 1.0.5 版本的库 SD 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SD
              使用 1.0 版本的库 SPIFFS 在文件夹: C:\Users\Administrator\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.2\libraries\SPIFFS
              exit status 1
              • sysdl132S Offline
                sysdl132
                questions at:
                • termInit();
                • printString((unsigned char*)initLogok);
                • termPutchar(c);
                • sysdl132S Offline
                  sysdl132
                  somebody???
                  • sysdl132S Offline
                    sysdl132
                    problems at...
                    void setup()
                    #ifdef ARDUINO
                    // Serial.begin(kConsoleBaud); // opens serial port
                    Wire.begin();
                    • termInit();
                    // while( !Serial ); // for Leonardo
                    Serial.println( sentinel );
                    // const unsigned char initlogo[] = "\n"
                    // " ___ __ \r\n"
                    // " / _ )/ /
                    _____ / /
                    \r\n"
                    // " / _ / / // / _ \/ '/\r\n"
                    //\, /////\\\r\n"
                    _/ v" " on " "\r\n"
                    // const unsigned char initLogo[] =
                    // " __ __ ____ \r\n"
                    // " | \/ | | \r\n"
                    \ \r\n"
                    // " | | | |) |\r\n"
                    ___/ \r\n"
                    "__ __ ____ ____ _ _ \r\n"
                    "| \/ | / || | __ _ | | \r\n"
                    \| / ` |/ | |/ / \r\n"
                    | < \r\n"
                    | ||// \\,|\_||\\ \r\n"
                    const unsigned char initLogox[] =
                    "## ## ######## ###### ######## ### ###### ## ## \r\n"
                    "### ### ## ## ## ## ## ## ## ## ## ## \r\n"
                    "#### #### ## ## ## ## ## ## ## ## \r\n"
                    "## ### ## ####### ###### ## ## ## ## ##### \r\n"
                    "## ## ## ## ## ######### ## ## ## \r\n"
                    "## ## ## ## ## ## ## ## ## ## ## ## ## \r\n"
                    const unsigned char initLogok[] =
                    "## ## ######## \r\n"
                    "### ### ## \r\n"
                    "#### #### ## \r\n"
                    "## ### ## ####### \r\n"
                    "## ## ## \r\n"
                    "## ## ## ## \r\n"
                    "## ## ###### \r\n";
                    const char initLogoz[] =
                    "'##::::'##:'########:\r\n"
                    "###::'###: ##.....::\r\n"
                    "####'####: ##:::::::\r\n"
                    "## ### ##: #######::\r\n"
                    "##. #: ##:...... ##:\r\n"
                    "##:.:: ##:'##::: ##:\r\n"
                    "##:::: ##:. ######::\r\n"
                    "..:::::..:::......:::\r\n";
                    const unsigned char initLogop[] =
                    " DD \r\n"
                    " DG DD \r\n"
                    " LD; # DD \r\n"
                    " DD # j## DD \r\n"
                    " DD # # # G\r\n"
                    " DD ## G, DDD\r\n"
                    " DD # DD D\r\n"
                    " D DD DD D\r\n"
                    " D DDGD. D\r\n"
                    " D D\r\n"
                    " Dj DD\r\n"
                    " iDD DG \r\n"
                    " DD DD \r\n"
                    " DD DG \r\n"
                    " GDDD \r\n";
                    // M5.Lcd.print(initLogoz);
                    printString((unsigned char*)"\r\nhttp://www.m5stack.com\r\n");
                    printString((unsigned char*)"Basic on the M5Stack library 0.1.2\r\n");
                    printmsg(initmsg);
                    // printmsg(initlogo);
                    #ifdef ENABLE_FILEIO
                    initSD();
                    #ifdef ENABLE_AUTORUN
                    if( SD.exists( kAutorunFilename )) {
                    program_end = program_start;
                    fp = SD.open( kAutorunFilename );
                    inStream = kStreamFile;
                    inhibitOutput = true;
                    runAfterLoad = true;
                    #endif /* ENABLE_AUTORUN */
                    #endif /* ENABLE_FILEIO */
                    #ifdef ENABLE_EEPROM
                    #ifdef ENABLE_EAUTORUN
                    // read the first byte of the eeprom. if it's a number, assume it's a program we can load
                    int val = EEPROM.read(0);
                    if( val >= '0' && val <= '9' ) {
                    inStream = kStreamEEProm;
                    eepos = 0;
                    #endif /* ENABLE_EAUTORUN /
                    #endif /
                    ENABLE_EEPROM */
                    #endif /* ARDUINO */
                    problems at:
                    • [text]
                      ptmartin
                      Hi sysdl132,
                      I hope you find this reply, I realize the post you made is 6 months old.
                      The way to get this to work is to make sure that when you download the m5stack_tinybasicplus.ino file you also have the TFT_Terminal.ino program in the same directory. the errors you are seeing are because the Arduino IDE apparently will include any .ino files that are in the project directory when it compiles.
                      I assume this is how it works, because at first I had the same error as you. I found the terminal .ino file in the same project, I opened it and realized that the code had the function termInit(); from the first error you mention, and I originally cut and pasted the code to get it to work.
                      I'm sorry no one replied. m5stack with the faces keyboard seems like it has some great potential but the documentation is so difficult to find and navigate it is really discouraging for beginners. I have been messing with SBCs and microcontrollers for about 5 years now and I still feel like a beginner. I hope the tutorials that I have seen in this forum help me learn more about this stuff.
                      Good luck and happy coding!
                      Petie
                      • sysdl132S Offline
                        sysdl132
                        PROBLEM SOLVED
                        Thanks for your reply.
                        I found function :
                        termInit();
                        termpurchar();
                        in the TFT_terminal.ino.
