    MQTT doesn't work
    Bug Report
    8
    11.6k
    • sysdl132S
      sysdl132
      Error:MQTT need,download...
      For Atom:115200/230400/921600
      • lukasmaximusL
        Would be useful to know some more information, such as the firmware you are running and on which device. Also a snapshot of your code wouldn't hurt too. Just posting mqtt doesn't work, doesn't really help us to solve your problem
        • world101W
          world101 @sysdl132
          @sysdl132 said in MQTT doesn't work:
          When using MQTT, you need to download the program to your device. You can’t just run your program with the play button.
          • sysdl132S
            sysdl132
            there is an another problem...
            Where is Unit earth`s port?
            • world101W
              world101 @sysdl132
              @sysdl132
              Seems to be a uiFlow bug. The Earth unit is a "port B" unit since it supports both analog and digital readings. If you go to settings and choose Device: core, the default port B shows up properly in uiFlow. But when you have Device: Stick-C, I see the same issue as you do. However, switching to the Python tab within uiFlow, it still shows the unit defined properly for the m5stickC since it only has one Grove port (A): earth0 = unit.get(unit.EARTH, unit.PORTA)
              If you have the Earth unit, please try it and see if it works properly so we can confirm it's just a display issue within uiFlow.
              • sysdl132S
                sysdl132
                Q3:I use a remote on my m5stickC and upload.(uiflow)First it works fine.The remote page on my phone is work fine.But few hours later,when I open it,QRCode is now work fine,but my phone display"No data"After refrash it still display"No data". What problem?
                • m5stackM
                  m5stack @world101
                  @world101 M5StickC can use Earth Unit in the Port A. it is a UI display problem. we will fix it.
                  • sysdl132S
                    sysdl132
                    Solved
