    M5StickC &18650C Hat
    Units
    18650c hat
    5
    11.3k
    • C
      ckuehnel
      I build a handheld thermometer based on M5StickC, 18650 hat and ENV hat.
      Now I am looking for the possibility to check the status of the 18650 LiPo and show it on TFT (see my blog).
      ajb2k3A W 2 Replies Last reply Reply Quote 0
      • H
        Hugo
        How to fix M5StickC in 18650C hat?
        Bottom of M5StickC still trying to go out.
        • C
          ckuehnel @Hugo
          @hugo I do not have this problem.
          Two quick&dirty proposals: 1. double sided tape between M5StickC and the hat or 2. drill two holes into the back of the hat and you can fix the M5StickC by two screws.
            ajb2k3 @ckuehnel
            @ckuehnel There doesn't look to be any control circuits in the 18650 hat and so you need an external controller fitted to the battery to provide that information.
            • W
              wjcarpenter @ckuehnel
              @ckuehnel Did you ever figure this out? I just got my 18650 hat. I took it apart and also don't see any control circuitry. I'm now guessing that the USB connector on the hat simply feeds into the 5V input of the M5StickC, and the AXP192 inside the M5StickC controls the charge of the 18650 cell. There is some info in the AXP192 data sheet about a back-up battery, but it's been a while since I read it, and I'm not sure it's relevant.
              One interesting thing ... I'm working on a project where I turn the display off after a few seconds if the M5StickC is not plugged in. Either by shrewd design or by my dumb luck, that works when the M5StickC is on the hat. ("It works" means the display turns off after a few seconds.)
