UiFlow 1.4.3
Ver 1.4.3. time : 2019.12.27
UpdateLog:- 1: Add: BaseX.
 - 2: Add: Server china and singapore select in setting.
 - 3: Fixed: in http request, it no longer auto converts string to json data.
 - 4: StickC: Fixed pahub unit support.
 - 5: StickC: Add: hat yun add humidity and temperature support.
 - 6: Fixed some bugs.
Issues:
Screen rotation is now flipped upside down
When I select the Singapore server, the M5Stack won't connect in uiFlow. I'm in the US, so perhaps there is a connection issue from here. The China server still works.
Always exciting to see new features added, is it possible to add the temp and humidity blocks you just released for the yun to the pm2.5.
@jpilarski said in UiFlow 1.4.3:
https://github.com/m5stack/UiFlow-Bug-Report/issues/20
chart function not working for the env sensor demo given in the UIFlow docs.
@world101 said in UiFlow 1.4.3:
Issues:
I meet this phenomenon too.
M5Stack Basic (text "2017.6" on the board)
UIFlow v1.32 and v1.42 are ok. -
Apparently the screen flip issue has been fixed...
link to twitter feedI’ll update the firmware on M5burner tomorrow and test again.
Looks like m5burner has been updated with the fixed 1.4.3 firmware. The screen is the correct orientation now. Just hit the X beside the firmware version, download it again, and reflash your m5stack.
we already fixed. pls delete the old firmware then download again.
Hello, community,
when will the offline version of UI-Desktop 1.4.3 be available.
When will it be released !?greeting skink
@skink i have not idea , maybe later.......
@m5stack ok, the new urequest implementation did cost me some time adapting the old code....
now also interruption of the wlan connection occurs more frequently, any improvements on that? Also I would need an example how to react to urequest failures via micropython try-catch, so far my code gest stuck.
