    M5-bit (Micro-Bit) part 2
    PROJECTS
    13.2k
    • ChrisWRC
      ChrisWR
      Turn your Micro-Bit leds on/off with the M5, create your own smilies on the M5.. ect..
      Here is the Micro-Bit code ;
      And te M5Stack code ;
      #include <M5Stack.h>
      #include <M5StackUpdater.h>
      #define WIDTH 320
      #define HEIGHT 240
      #define BLOCK_SIZE  40
      #define UNIT_WIDTH  5
      #define UNIT_HEIGHT 5
      #define UNIT_SIZE 25
      #define GETX(i) ((i) % (5))
      #define GETY(i) ((i) / (5))
      int world[UNIT_SIZE];
      int i;
        Wire.begin();
        if(digitalRead(BUTTON_A_PIN) == 0){
          Serial.println("Will load menu binary");
          updateFromFS(SD);
          ESP.restart();
        Serial2.begin(115200, SERIAL_8N1, 16, 17);
        M5.Lcd.fillScreen(BLACK);
        M5.Lcd.setTextSize(2);
        M5.Lcd.setCursor(35, 220);
        M5.Lcd.println("  <       *       >");
          for (i = 0; i < UNIT_SIZE; i++) {
          world[i] = 0;
        i = UNIT_SIZE / 2;
            M5.update();
            int x = GETX(i) + 1;
            int y = GETY(i);
            if (world[i] > 0) M5.Lcd.fillRect(x * BLOCK_SIZE + 1, y * BLOCK_SIZE + 1, BLOCK_SIZE - 2, BLOCK_SIZE - 2, LIGHTGREY);
            else M5.Lcd.fillRect(x * BLOCK_SIZE + 1, y * BLOCK_SIZE + 1, BLOCK_SIZE - 2, BLOCK_SIZE - 2, BLUE);
            if (M5.BtnC.wasPressed()) {
               if (world[i] > 0) M5.Lcd.fillRect(x * BLOCK_SIZE + 1, y * BLOCK_SIZE + 1, BLOCK_SIZE - 2, BLOCK_SIZE - 2, WHITE);
               else M5.Lcd.fillRect(x * BLOCK_SIZE, y * BLOCK_SIZE, BLOCK_SIZE, BLOCK_SIZE, BLACK);
               ++i;
               if (i >= UNIT_SIZE) i=0;
            if (M5.BtnA.wasPressed()) {
               --i;
               if (i < 0 ) i=UNIT_SIZE -1;
            if (M5.BtnB.wasPressed()) {
              if (world[i] > 0) world[i]=0;
              else world[i]=1;
              Serial2.print(world[i]);
              Serial2.print(GETX(i));
              Serial2.println(GETY(i));
      On the M5; button A moves left, button C moves right and button B toggles the led, this shows on Micro-Bit and M5
      • world101W
        world101
        This is great, but could you please format your code correctly when posting so we can read it? You do that by pasting your code enclosed within three back ticks (```) on the same line or separate lines.
        like this or
        like this
        ChrisWRC 1 Reply Last reply Reply Quote 0
        • ChrisWRC
          ChrisWR @world101
          @world101 ok, thx
            ajb2k3 @ChrisWR
            @chriswr said in M5-bit (Micro-Bit) part 2:
            @world101 ok, thx
            Much better.
            Is the a uiflow blocky version of you latest code?
            • ChrisWRC
              ChrisWR @ajb2k3
              @ajb2k3 Its not uiflow, its makecode (for micro-bit) and arduino for m5
                ajb2k3 @ChrisWR
                @chriswr I understand that it make code for the microbit but i was hoping you would consider using m5stacks uiflow for the m5stack products just to be consistant.
                Apart from this, nice work and please keep sharing!
                ChrisWRC 2 Replies Last reply Reply Quote 0
                • ChrisWRC
                  ChrisWR @ajb2k3
                  • ChrisWRC
                    ChrisWR @ajb2k3
