    Color Sensor RGB Unit UI 1.3.2 (TCS3472) / R G B Data always on 0
    Bug Report
    4.7k
    • AlfA
      Alf
      My sensor only shows me the RAW data.
      The values of R G B (single) are always 0.
      UI V1.3.2 / V 1.4.0
      Contains a calibration table which is probably wrong:
      1. values smaller than 0 must be set to zero
        If the calibration table matches the integration time of 154 MS. The Arduino example assumes 50 MS.
      3 The module reacts logarithmically. So it should not be approximated with a 3rd degree function !
      Could this be checked?
      I would like to make an instruction video on my Youtube channel (UI Flow),
      but I can't get any further.
      Alf
        Contact me after 6pm GMT on Discord and I will see what I can do.
