    Broplem with M5Go Batterie by buy from aliexpress
    Scheduled Pinned Locked Moved Bases
    2 Posts 1 Posters 5.8k Views 1 Watching
    • L Offline
      lfleron
      Hello, I'm having problems with port C. The unitLight sensor does not always give the analog value I think of a false contact with contacts barettes interior (2 * 15). If I screw the two hex screws, the analog input of port C no longer works. If I remove the screws the port C works normally. What can I do for me? See the video Thank you.
      I filed a dispute on Aliexpress and the problem is not recognized by M5Stack.
      The problem is not the charging of the battery. The battery is charging well
      It is a problem of receiving data on the port when the plastic box is screwed.
      When the screws are removed all is well.
      I think the problem is false contact.
      I test the M5Stack products for use with students and I want to have reliable products because I will buy a lot.
      What can you do to solve the problem?
      Thank you
      • L Offline
        lfleron
        After 3 successive orders, the bases have all three a defect of connectivity.
        I think the heights of the pins of the contacts are not high enough and do not fit in the header.
        View the photo :
