    M5StickV link/Info dump.
    Scheduled Pinned Locked Moved M5Stick V
    14 Posts 5 Posters 31.4k Views 5 Watching
      staberas
      hey can anyone confirm me what the value of getBatteryDischargeCurrent() is ? is it mA or battery % ?
      • X Offline
        Xeon @staberas
        @staberas
        getBatteryDischargeCurrent() will show you the mA currently being drawn when the device is not being charged.
        The war of 1 and 0 draws ever closer.
        everyday i work to become a cyborg.
          staberas @Xeon
          @xeon
          Thanks, so if the value i get is 100mA then i have ~2hours run time based on the 200mAh battery correct? thou i have to keep the time passed since the last check to estimate battery %
          • X Offline
            Xeon @staberas
            @staberas
            Theoretically yes.
            it should be near 2 hours.
            under heavy workloads it peaks to +-115mA
              staberas
              Adding my demo project as a sandbox for other users : https://github.com/staberas/Joker-Masks-M5StickV , it covers faces with joker mask
                staberas
                Can anyone point me on how you use the expansion slot?
                  ajb2k3 @staberas
                  @staberas said in M5StickV link/Info dump.:
                  what expansion slot?
                    staberas @ajb2k3
                    4pin expansion PH2.0-4
                      ajb2k3 @staberas
                      @staberas The grove port under the USB port?
                      Does it not work as a normal Grove Port A?
                        staberas @ajb2k3
                        yes, cant seem to find info on it
                        EDIT: i started testing the pins and i cant detect a voltage output
