    M5StickV Firmware_1017 Upgrade
    24 Posts 7 Posters 99.1k Views 1 Watching
      staberas @Thrasher
      @thrasher
      does the sd contain the project? (boot.py)
      if yes then upload it on the flash memory via maixpy and rename the "boot.py" on the sd card to "_boot.py"
        Thrasher
        @staberas
        Okay, will give it a try. Usually used simply copy files to sd card and it used to work well (alrdy did tests with old firmware)
          Thrasher
          Didn't work.
          Tried both upload file and "save open script to board(boot.py)
          No effect at all
          Does anyone there have old firmware so I can try with it?
            staberas @Thrasher
            @thrasher
            http://dl.sipeed.com/MAIX/MaixPy/release/master/
              Thrasher
              @staberas
              Thank you. I've tried this - "maixpy_v0.4.0_6_g715665c_m5stickv.bin" with kflash_gui.
              Works like a charm now and power button also works correct (lol)
              • SkinkS Offline
                Skink
                I've been taking this version online at yesterday.
                (Link: http://dl.sipeed.com/MAIX/MaixPy/release/master/)
                Version : maixpy_v0.4.0_66_g4ab9e8d and also with this version switching off the stick works now !!
                  Cant use Kflash gui on my OSX install. Whats the command line to install the firmware?
                  • SkinkS Offline
                    Skink
                    I don't know if this will help you because I don't have an Apple!
                    Kflash
                    3, For people who are used to use command line, Kflash could be an alternative option.[Click here for details](https://github.com/kendryte/kflash.py)
                    Reiner
                      FPSychotic
                      What is PMU module?
                      • m5stackM Online
                        m5stack @FPSychotic
                        @fpsychotic power managment unit
                        • m5stackM Online
                          m5stack @Thrasher
                          @thrasher hi thanks your reply , we will as soon solve this problem.
                          • X Offline
                            Xeon
                            I am making a manual that tries to fullty detail all functions for the m5stickV and K210
                            is this ok?
                            Would people support this?
                            The war of 1 and 0 draws ever closer.
                            everyday i work to become a cyborg.
                            m5stackM T 2 Replies Last reply Reply Quote 2
                            • m5stackM Online
                              m5stack @Xeon
                              @xeon Nice !
                                Thrasher @Xeon
                                @xeon
                                Sure that would be awesome. Especially UART and other things becayse Maix manuals say nothing about it.
                                There's a thread already ran to collect all things about Stick-V, could you keep it updated so we gather all necessar info in one thread ? here it is - http://forum.m5stack.com/topic/1226/m5stickv-link-info-dump/1
                                X 1 Reply Last reply Reply Quote 1
                                • X Offline
                                  Xeon @Thrasher
                                  @thrasher
                                  Well i'm going to start by documenting all the functions in the maix core and then start fleshing it out.
                                  I created a git to hold manual but right now it just a mess.
                                  And will open it up to others to help flesh it out in detail.
                                  A lot of stuff is not documented.
                                  Some stuff can easily be described.
                                  Other stuff needs me to read thru data sheets carefully.
                                  I'll also be looking into our microphone issue.
                                  And supplying links to more articles on growing the AI platform.
                                    ajb2k3 @Xeon
                                    @xeon said in M5StickV Firmware_1017 Upgrade:
                                    @thrasher
                                    Welcome to my world @Xeon
                                      Thrasher
                                      @ajb2k3 @Xeon
                                      I can help to translate into russian, with time.
                                      Whenever Ill have spare minute
                                        ajb2k3 @Thrasher
                                        @thrasher said in M5StickV Firmware_1017 Upgrade:
                                        @ajb2k3 @Xeon
                                        Thank you your support will be most appreciated
                                          staberas
                                          new bug:
                                          "pmu import axp192" interferes when i try to get gyro/accel data from the MPU6886
                                          • m5stackM Online
                                            m5stack @staberas
                                            @staberas actually it not a bug . the K210 only three I2C interface, camera ,and some hardware dafuit use two interface . then PMU use one interface , if you want to use IMU , you shoud be Reasonable distribution I2C interface.
