    Purchased a m5StickV - Fixed in recent firmware update.
    25 Posts 4 Posters 92.5k Views 1 Watching
    • X Offline
      Xeon
        ajb2k3 @Xeon
        @xeon said in Purchased a m5StickV:
        Holding the power button 6 seconds to try turn it off.
        It keeps powering back on right away.
        1. for the love of all that is holy.
          Tell people that sell your device the mic is broken and your looking to dump the project and your losses on it.
        2. if you make a basic firmware, make sure the off button actually does what the manual says.
        3. the manual covers less than some terrible products.
        4. i can't even understand it's quirks.. connecting via serial reboots it??
          Then serial monitor is lost searching.
        Starting to think i made a huge mistake.
        such a awesome device.. so much potential.
        :edit
        reflashed stock.
        still can't turn it off.
        am i missing a trick?
        How did you reflash it, what firmware did you use?
        BTW the microphone issue only came up after the release and there was an announcement about the issue
        • X Offline
          Xeon
          i used kflash_gui V1.5.3
          used the latest firmware.
          http://dl.sipeed.com/MAIX/MaixPy/release/master/maixpy_v0.4.0_52_g3b8c18b
          do i need a script present ?
          • X Offline
            Xeon @Xeon
            Ahh Sorry.. idk what happened.
            i apologize if i seem aggressive the device was acting very odd.
            i purged my serial drivers and reflashed
            Seems to be working as i hoped.
            ty for not banning me.
              ajb2k3 @Xeon
              @xeon No worries, I've been having issues aswell but reflashing does help
              • X Offline
                Xeon @ajb2k3
                the problem came back.
                i don't know how.
                  ajb2k3 @Xeon
                  i don't know how.
                  After a reflash the issue is back?
                  Please email the M5Stack support people. something is defiantly not correct.
                  • X Offline
                    Xeon @ajb2k3
                    i found a few work arounds.
                    1. Cant turn off
                      Letting the battery run out seems to solve the power button.
                      As it works fine again afterward.
                    2. Keeps bugging out after running a script in Maix Py ide
                      Disconnect a reconnect
                    • X Offline
                      Xeon
                      device begins doing this when fully charged.
                        FPSychotic
                        Same issues here
                        • X Offline
                          Xeon @FPSychotic
                          @fpsychotic
                          Did yours get very hot while charging?
                            ajb2k3 @Xeon
                            @fpsychotic
                            Yes, mine does get hot
                            BTW there is already a MK2 on its way.
                              Thrasher
                              Mine cant last long with battery.. I left it to charge for couple of hours and after that it worked maybe 2 minutes.. I keep it plugged into powerbank
                                FPSychotic @ajb2k3
                                Not really and it last some time with battery.
                                v2? the wifi one? if is not wifi, what is the difference and were you got?
                                  ajb2k3 @FPSychotic
                                  @fpsychotic I've got the MK1 as the MKII isn't out yet
                                  • X Offline
                                    Xeon
                                    i verified it.
                                    after reaching 70 to 90% full battery the device wont power off.
                                    it just reboots.
                                    after going below this threshold it turns off again normally.
                                      Thrasher
                                      Hardmode it with dc-dc stepdown to keep battery outcome always below 70% :))
                                      • X Offline
                                        Xeon
                                        Well my battery is now rotten thanks to this.
                                        The battery life is fading very fast.
                                        I want a replacement.
                                        i bought this device to get a task done.
                                        it's going to.
                                          ajb2k3 @Xeon
                                          @xeon have you contacted M5Stack support about this? They should be available now
                                          • X Offline
                                            Xeon @ajb2k3
                                            @ajb2k3 said in Purchased a m5StickV:
                                            They verified the problem and will release a fix soon.
