šŸ¤–Have you ever tried Chat.M5Stack.com before asking??šŸ˜Ž
    Faces items without baseplate
    Units
    5
    8
    10.7k
    • P
      Powersoft
      Is it posible to use Face items ā€œwithoutā€ the baseplate together with the M5Stack Gray? I’m interested in the rotary swich only!
      Cheers
      Jan
        ajb2k3 @Powersoft
        @powersoft It should be as I have the fingerprint and rfid face but I haven't had time to look into it!
        • P
          Powersoft
          Thanks for the respons, please can you make a picture of the front of of the fingerprint device, so I can see how it will be attached to the M5Stack Gray.
          Thanks in advance.
          Cheers,
          Jan
            Here is the docs for it.
            https://docs.m5stack.com/#/en/module/faces_finger
            • P
              Powersoft
              Thanks, found the documentation of the faces-encoder. On the picture you can see that the only connection is posible via the base plate. Connection is looking to the up side, and the connector of the gray is horizontal. I think this will not fit
              • lukasmaximusL
                @Powersoft The only way to connect the M5Stack to the face plates without the baseplate would be via dupont cables, but the connection wouldn't be very stable this way. On our official store you should be able to buy the base with encoder
                • B
                  Bas
                  I just connected the fingerprint face to an M5stack fire.
                  Wanted to extract the image from the unit.
                  To my surprise it turns out not to be 192 but rather 160 pixels.
                  You can see this on the screenshots 0x6400 is the image lenth which is 160x160 at 8 bits.
                  • m5stackM
                    m5stack @Bas
                    @bas actually it was 160*160, the product document has a mistake , at now it was fix , thanks your reply.
