    Uiflow HTTP request
    UIFlow
    7
    9
    26.4k
    • H
      hetzer
      Did anyone manage to make this new ui function work?
        ajb2k3 @hetzer
        @hetzer not yet, just seen the new functions that have been added
        • R
          rupin.chheda
          Yes, Kind of. But there is weird Behaviour.
          I used the following simple block
          0_1570255790792_d78f81f7-e728-4887-9a6d-3f4ae5163d4f-image.png ![alt text](image url)
          When I run the program using the play button on UIFlow, I get the text "Ok" printed on the LCD.
          I get excited and I download the code into the Device, and I get to see the text " Not OK"
          The Python Error I get is "list index out of range"
          Here is my modified code
          from m5stack import *
          from m5ui import *
          from uiflow import *
          import urequests
          setScreenColor(0x222222)
          label0 = M5TextBox(40, 93, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
          try:
          req = urequests.request(method='GET', url='https://api.thingspeak.com/apps/thinghttp/send_request?api_key=AAXWP1R39OHJW1U1', headers={'Content-Type':'text/html'})
          lcd.print('ok', 0, 0, 0xffffff)
          except Exception as e:
          lcd.print('not ok', 0, 0, 0xffffff)
          label0.setText(str(e))
          • lukasmaximusL
            @rupin-chheda It works fine for me after downloading. I think it could be that when running a downloaded program it doesn't auto connect to the wifi, so you have to use the network blocks to setup your wifi, heres my example:
            • W
              Wolli01
              With https it's not just with http!
              Use this solution for now
                url = str(settings.Gateway.replace("https", "http")) #Es darf nur http genutzt werden kein https
                res3 = urequests.get(url)
              • R
                rupin.chheda @lukasmaximus
                @lukasmaximus This worked! thanks!
                • J
                  jpilarski
                  Where is the key value block, it no longer is in the map blocks. Can I please get an example of how to use one of the newer alternate blocks currently available.
                  • world101W
                    world101 @jpilarski
                    @jpilarski said in Uiflow HTTP request:
                    Isn’t it here when you press the + button in the map?
                    • J
                      jpilarski
                      Thanks so much I totally overlooked the plus sign and I was searching for a block in the map blocks. I’m grateful for you answering my question.
