    Memory related issue
    4 Posts 3 Posters 13.7k Views 3 Watching
      remeshck
      I am using M5Stack-Core_esp32 . compiler arduino.
      when i compile my program it is showing that "sketch uses 1460566 bytes (111%) of program storage maximum is 1310720.
      I have used OTA code , BLE and uart. How can i increase program memory. It is suppose to be 2MB.
      It is showing only 1.25MB.
      • JJJ Offline
        JJ @remeshck
        @remeshck Hi Remeshck,
        Check the discussion at the link below... hope it helps.
        http://forum.m5stack.com/topic/132/m5stack-ble-client-for-owon-b35t-multimeter/3
        • reaper7R Offline
          reaper7
          from http://desire.giesecke.tk/index.php/2018/01/30/change-partition-size/
          inside ..esp32\tools\partitions add new file for e.g. bigapp.csv with content:
          # Name,   Type, SubType, Offset,  Size, Flags
          nvs,      data, nvs,     0x9000,  0x5000,
          otadata,  data, ota,     0xe000,  0x2000,
          app0,     app,  ota_0,   0x10000, 0x1E0000,
          app1,     app,  ota_1,   0x1F0000,0x1E0000,
          eeprom,   data, 0x99,    0x3F0000,0x1000,
          spiffs,   data, spiffs,  0x3F1000,0xF000,
          and inside esp32\boards.txt add new(copy) board like:
          m5stack_bigapp.name=M5Stack_bigapp
          m5stack_bigapp.upload.tool=esptool
          m5stack_bigapp.upload.maximum_size=1966080
          m5stack_bigapp.upload.maximum_data_size=294912
          m5stack_bigapp.upload.wait_for_upload_port=true
          m5stack_bigapp.serial.disableDTR=true
          m5stack_bigapp.serial.disableRTS=true
          m5stack_bigapp.build.mcu=esp32
          m5stack_bigapp.build.core=esp32
          m5stack_bigapp.build.variant=esp32
          m5stack_bigapp.build.board=M5Stack_bigapp
          m5stack_bigapp.build.f_cpu=240000000L
          m5stack_bigapp.build.flash_size=4MB
          m5stack_bigapp.build.flash_mode=dio
          m5stack_bigapp.build.boot=dio
          m5stack_bigapp.build.partitions=bigapp
          m5stack_bigapp.menu.FlashMode.qio=QIO
          m5stack_bigapp.menu.FlashMode.qio.build.flash_mode=dio
          m5stack_bigapp.menu.FlashMode.qio.build.boot=qio
          m5stack_bigapp.menu.FlashMode.dio=DIO
          m5stack_bigapp.menu.FlashMode.dio.build.flash_mode=dio
          m5stack_bigapp.menu.FlashMode.dio.build.boot=dio
          m5stack_bigapp.menu.FlashMode.qout=QOUT
          m5stack_bigapp.menu.FlashMode.qout.build.flash_mode=dout
          m5stack_bigapp.menu.FlashMode.qout.build.boot=qout
          m5stack_bigapp.menu.FlashMode.dout=DOUT
          m5stack_bigapp.menu.FlashMode.dout.build.flash_mode=dout
          m5stack_bigapp.menu.FlashMode.dout.build.boot=dout
          m5stack_bigapp.menu.FlashFreq.80=80MHz
          m5stack_bigapp.menu.FlashFreq.80.build.flash_freq=80m
          m5stack_bigapp.menu.FlashFreq.40=40MHz
          m5stack_bigapp.menu.FlashFreq.40.build.flash_freq=40m
          m5stack_bigapp.menu.UploadSpeed.921600=921600
          m5stack_bigapp.menu.UploadSpeed.921600.upload.speed=921600
          m5stack_bigapp.menu.UploadSpeed.115200=115200
          m5stack_bigapp.menu.UploadSpeed.115200.upload.speed=115200
          m5stack_bigapp.menu.UploadSpeed.256000.windows=256000
          m5stack_bigapp.menu.UploadSpeed.256000.upload.speed=256000
          m5stack_bigapp.menu.UploadSpeed.230400.windows.upload.speed=256000
          m5stack_bigapp.menu.UploadSpeed.230400=230400
          m5stack_bigapp.menu.UploadSpeed.230400.upload.speed=230400
          m5stack_bigapp.menu.UploadSpeed.460800.linux=460800
          m5stack_bigapp.menu.UploadSpeed.460800.macosx=460800
          m5stack_bigapp.menu.UploadSpeed.460800.upload.speed=460800
          m5stack_bigapp.menu.UploadSpeed.512000.windows=512000
          m5stack_bigapp.menu.UploadSpeed.512000.upload.speed=512000
          m5stack_bigapp.menu.DebugLevel.none=None
          m5stack_bigapp.menu.DebugLevel.none.build.code_debug=0
          m5stack_bigapp.menu.DebugLevel.error=Error
          m5stack_bigapp.menu.DebugLevel.error.build.code_debug=1
          m5stack_bigapp.menu.DebugLevel.warn=Warn
          m5stack_bigapp.menu.DebugLevel.warn.build.code_debug=2
          m5stack_bigapp.menu.DebugLevel.info=Info
          m5stack_bigapp.menu.DebugLevel.info.build.code_debug=3
          m5stack_bigapp.menu.DebugLevel.debug=Debug
          m5stack_bigapp.menu.DebugLevel.debug.build.code_debug=4
          m5stack_bigapp.menu.DebugLevel.verbose=Verbose
          m5stack_bigapp.menu.DebugLevel.verbose.build.code_debug=5
          then for your big apps you can select this board
          • JJJ Offline
            JJ @reaper7
            @reaper7 Hi Reaper7,
            thanks for adding that helpful example.
