    Ui Flow 1.3.2 (web) has dropped Stick
    Bug Report
    9
    14.8k
    • I
      iPodLux
      Hi
      I’ve noticed the new 1.3.2 has no longer support for the grey/white Stick. Is it temporary or shall we kiss goodbye to our little fellas?
      Cheers
      • H
        heybin
        We are very sorry, stick-UIFlow is stop update
          ajb2k3 @iPodLux
          @ipodlux as long as you can remember the limits of the gray, it can still be programmed as an M5Stack.
            ajb2k3 @heybin
            @heybin this is a bad idea as there are too many out in the wild, you need to keep supporting the stick for another two years minimum!
            • I
              iPodLux
              Indeed, making a device obsolete after months it's not a good practice and won't look good on the 'brand'. 60$ in the bin...
              • MatiM
                Mati
                Bump
                So what now Stick Gray is end of life ?!
                  With the StickC and StickV the stick is obsolete however, as I mentioned it can still be programmed in UIFlow
                  MatiM 1 Reply Last reply Reply Quote 0
                  • MatiM
                    Mati @ajb2k3
                    @ajb2k3 yes in old version ... there was any reply from official guys about it ?
                      ajb2k3 @Mati
                      @mati said in Ui Flow 1.3.2 (web) has dropped Stick:
                      The offical answer was that it is obsolete and they don't need to support it.
