    UiFlow upgrade
    UIFlow
    12.8k
    • K
      Kees1949
      Actually it's not possible to download UiFlow v 1.0.2 and firmware v 1.3.5-beta in Windows10.
      Can somebody help with it?
        ajb2k3 @Kees1949
        @kees1949 Others have managed it, what is the problem?
        • K
          Kees1949
          After using the button "Update Now" the system reports "Downloading" and nothing happens any more. Later the system reports "Download failed".
          The download of the firmware doesn't report anything at all.
          • OyczEO
            OyczE
            Make sure drivers is proper installed and mstack unit is recognized under devices on some COM port.
            • K
              Kees1949
              I'm speaking about the dowload to the PC, not to the M5Stack.
              • OyczEO
                OyczE @Kees1949
                @kees1949 said in UiFlow upgrade:
                Ahh
                Right after check all is fine. From download we got 1.0.1 then check fot update works fine for me. 1.0.2 was detected and auto downloaded without any problem.
                • K
                  Kees1949
                  With the standalone version of M5Burner it is possible to download and upgrade the firmware on the M5Stack. However after that the versions on the PC and the M5stack are not synchronous.
                  • K
                    Kees1949
                    A complete new download and installation of the UiFlow Desktop has solved the issue.
