    Extrusion mould issue causes crack
    PRODUCTS
    7.9k
    • on4aaO
      on4aa
      I had to perform an emergency repair on the housing of a black M5Stack core. The housing started to crack spontaneously on one of its edges, despite hardly using it.
      crack
      I am suspecting a extrusions mould issue causing to little material to flow to that edge. Such an issue can be corrected on the extrusion mould by adding an extra channel.
      Serge — http://hamwaves.com/iot/
      • m5stackM
        Do you use it violently?
        on4aaO 1 Reply Last reply Reply Quote 0
        • on4aaO
          on4aa @m5stack
          @m5stack No, not at all! It was just sitting on my desk and over the course of two days a crack appeared and gradually grew over the whole width. The other three edges show no problem. This is why I suspect a problem with the extrusion mould.
