    How to use Back Buffer for drawing ?
    SOFTWARE
    8
    15.2k
    • P
      progman
      I want use Back Buffer for drawing my scene.
      I want draw all scene to BB and after that draw BB to screen.
      With BB I will have no blink effect. And can redraw all screen each frame.
      How to create BB and use it? I did not found API for that
      • lukasmaximusL
        Hi @progman the graphics library on the M5Stack is quite limited not sure there is a back buffer. If you are looking to layer images, create sprites and tiles for games or UI you could check out the arduboy library https://github.com/phillowcompiler/ArduboyOnM5StackFACES or the stage tile and sprite library https://www.hackster.io/deshipu/stage-a-tile-and-sprite-engine-e9e655
          ajb2k3 @progman
          @progman said in How to use Back Buffer for drawing ?:
          Unfortunately not enough people are working on UIFLOW/Micropython graphics at the moment and so not much is known.
          • T
            Thrasher
            Unfortunately, thats a big problem. Lack of information/examples/libraries and such pushing people away from M5Stack devices. I've talked to my partners, and they said they not gonna switch until more docs/libs available. Hopefully M5Stack team will focus on this someday
              ajb2k3 @Thrasher
              @thrasher I’m currently working on the UIFlow document and have some WIP document uploaded in the project forum. Any feedback on them will be great fully accepted
              • T
                Thrasher @ajb2k3
                @ajb2k3 I can help with translation if you're interested, shoot me a message via p.m.
                Thanks!
                  ajb2k3 @Thrasher
                  @thrasher thanks please have a look at what I have uploaded so far. My main document in in the UIFlow roadmap discussion.
                  • lukasmaximusL
                    Hi @Thrasher, did you take a look at those libraries? you still didn't mention what it is that you want to do. There is also the framebuf library that may help, search framebuf.py on github
