    M5Stick C UI Flow WIFI Connection Problem.
    UIFlow
    8
    16.1k
      sephiroth
      Hi There,
      I've been looking for a solution to connecting stick c to wifi.
      how did I flow;
      1: install Silicon Labs VCP Driver
      2: M5 burner ( ui flow 1.3.5-beta)
      3: I entered the interface ( 192.168.4.1)
      4: I entered the wifi and password
      any ideas?
      thanks.
        Something is not working on your end. If you are getting that screen then your computer and M5Stack are chatting but that error message is because your modem and m5stick won’t chat. Double check your passwords as they are case sensitive.
        Are you trying to connect to a private WiFi or an enterprise WiFi as there are issue with enterprise WiFi access points
          sephiroth @ajb2k3
          @ajb2k3 Yes , I checked password and I tried different modems. Also I did all the operations again and again. :(
          • C
            crochi5
            I had the same problem...I renamed my WIFI...well I only deleted the blank and finally it worked
              sephiroth @sephiroth
              @sephiroth https://www.facebook.com/ersanmars/videos/10162033445670153/?multi_permalinks=363227004593049&notif_id=1565943361304051&notif_t=feedback_reaction_generic
                sephiroth @crochi5
                @crochi5 hello, how did you change?
                • C
                  crochi5 @sephiroth
                  @sephiroth I changed the name of my wifi on the router from e.g. xyz zyx --> xyzzyx
                  that did it for me
                  • T
                    Thrasher
                    Its common bug, neither Core nor Stick would connect to AP with space in its name. e.g. will not connect to "My Wifi" network, but will work with "MyWifi". %20 trick also didnt work for me, had to rename mine aswell
