    Goplus dc motor driver
    20 Posts 5 Posters 45.1k Views 1 Watching
      ajb2k3 @rob.biernat
      @rob-biernat I don't have one so I cant guess but there are several different versions of the 2pin JST. In what way does it not fit and can you provide photos of the connections?
        rob.biernat
        My blower fan uses what I think is jst ph series which has a 2mm pitch.
        It seems like it's a fraction too large for the m5 stack though.
        Surely someone on this forum knows the specifics?
          ajb2k3 @rob.biernat
          @rob-biernat Normally the fans connections are using the 2.54mm JST PH spacing which would explain the issues.
            rob.biernat
            Ok no probs. For now I have stuff going with a jumper wire hack but I can buy some proper jst cables tommorow.
            Is the person who wrote the go plus firmware and sample code on this forum? I can understand most of the code but since the code is not documented and not included in the m5 stack arduino library I need some help understanding the messages that get sent out on the i2c bus and what they do.
              ajb2k3 @rob.biernat
              @rob-biernat Looks like he is but he is not active.
              @zhouyang can you help?
                rob.biernat
                Ok so I have the dc motor controller working but when will the sample code be cleaned up and documented. At the moment it's a bit rough with lots of magic numbers scattered through the code. Ideally a proper api
                  rob.biernat
                  Any updates from the bloke who wrote the code?
                    rob.biernat
                    Anything from the programmer?
                      ajb2k3 @rob.biernat
                      @rob-biernat said in Goplus dc motor driver:
                      Nope, still waiting.
                      • lukasmaximusL Offline
                        Is this the code in question?
                        #include <Arduino.h>
                        #include <M5Stack.h>
                        #define IrPin 13
                        #define PLUS_ADDR 0x62
                        int32_t number = 0;
                        uint8_t press = 0;
                            M5.begin(true, false, false);
                            M5.Lcd.setTextFont(6);
                            M5.Lcd.clear(BLACK);
                            M5.Lcd.setTextColor(ORANGE, BLACK);
                            Wire.begin();
                            ledcSetup(1, 38000, 10);
                            ledcAttachPin(IrPin, 1);
                        void plus_encode() {
                            Wire.requestFrom(PLUS_ADDR, 2);
                            while(Wire.available()) {
                                int8_t encode = Wire.read();
                                uint8_t press_n = Wire.read();
                                number += encode;
                                if(press_n == 0xff) {
                                    press = 0;
                                else {
                                    press = 1;
                            char data[20];
                            plus_encode();
                            ledcWrite(1, ledcRead(1) ? 0 : 512);
                            sprintf(data, "%d  %d        ", number, press);
                            M5.Lcd.setCursor(100, 100);
                            M5.Lcd.print(data);
                            vTaskDelay(200);
                        I have a feeling the engineer who wrote the code may no longer work at M5Stack but i'll make an enquiry.
                        • L Offline
                          liushasha
                          @rob-biernat
                          PH2.0
                          https://item.taobao.com/item.htm?spm=a1z10.3-c-s.w4002-21223910208.112.64e66a4bJ99Q2L&id=522578768957
                            rob.biernat
                            Ok given the bloke who wrote the code has left can someone please at least document the i2c messages?
                            • V Offline
                              vany5921
                              https://github.com/m5stack/GoPlus/blob/master/src/src.ino this is sourece code
