    M5Stack FIRE can't maintain connection in UIFlow
    UIFlow
    6
    8.0k
      A Former User
        ajb2k3 @A Former User
        @jchipjonty
        Some questions that we need answers to before we can help.
        Q1 What firmware do you have installed on your M5 Fire?
        Q2 What UIFlow version are you using?
        Q3 What operating system is your computer running?
        Q4 What web browser are you using for UIFlow?
        Q5 How does you M5Fire connect to the internet? (is it a private modem, enterprise modem or college access point?)
        Q6 Have you tried connecting to a different modem? (Some phones can work as access points)
        Q7 What is printed on the white square on the M5Fires PCB?
        • V
          viernesmatheus
          Hi. I have the same problem. My M5Stick only connects to UIFlow after a click the option Connect for several times.
          AQ1: 1.3.2
          AQ2: same
          Aq3: OS
          AQ4: Chrome
          Aq5: Private connection at my home
          aq6: no
          aq7: the key and the globe is green.
          H ajb2k3A 2 Replies Last reply Reply Quote 0
          • H
            hetzer @viernesmatheus
            @viernesmatheus Same here, cant connect
              ajb2k3 @viernesmatheus
              @viernesmatheus said in M5Stack FIRE can't maintain connection in UIFlow:
              AQ1: 1.3.2
              AQ2: same
              Aq3: OS
              AQ4: Chrome
              aq6: no
              looks like the server at fault, should be working within 24 hours based on the programmers previous work.
                A Former User
