    Please allow jtag or jtag over usb on next version
    jtag
    25 Posts 9 Posters 110.3k Views 2 Watching
      rleinfellner
      The current M5Stack module is excellent other than the the fact that it does not support jtag.
      This major omission reduces its usability for anything but the most trival applications.
      I am sure there is another pin which could be used for the lcd chip select.
      Regards
      Richard
      B R 2 Replies Last reply Reply Quote 5
        I don’t understand why you would want jtag when you can program OTA, USB and UART
        1 Reply Last reply Reply Quote -3
          rleinfellner
          I find JTAG great for real time debugging with H/W breakpoints and variable watching, its also fast. I think its fine it has the other methods also, however its would be good to have JTAG availiable. Even better would be using a dual channel USB chip which could handle JTAG without the seperate programmer like the WROVER DevKit.
          All the pins other then GPIO14 are availiable, however for some reason it was used for LCD CS on the M5Stack rendering JTAG unuseable.
          • mickM Offline
            mick
            Agree, vote plus 1 for JTAG.. Sales will definitely increase. M
            • 5 Offline
              5trace
              This is a major omission from the M5Stack's capabilities.
              No JTAG debugging, what were they thinking?
              • B Offline
                bobolink @rleinfellner
                @rleinfellner
                Wouldn’t you want the JTAG scan path clear for automated factory testing?
                  repligon @rleinfellner
                  The lack of debugging is literally the only reason that stops me from buying the stack.
                    ajb2k3 @repligon
                    @repligon you can debug over the usb connection or over UART
                    R 1 Reply Last reply Reply Quote -2
                      Thrasher
                      ajb2k3A B 2 Replies Last reply Reply Quote 0
                        ajb2k3 @Thrasher
                        @thrasher said in Please allow jtag or jtag over usb on next version:
                        As far as I understood from different forums/github, we dont have jtag available because one of the pins is used to work with LCD. This case, it appears to be possible to hardmode m5stack, Im thinking of cutting pcb trace of this pin, add 2 point switch which will either connect it to lcd or work as jtag. With some skill you can even dremel a small hole on the side and put switch there
                        Now that sounds like a good plan for an enterprise version of the M5Stick.
                        If you have facebook post this on the Official group and PM Jimmy Lau!
                          Thrasher
                          • B Offline
                            bobolink @Thrasher
                            @thrasher But don’t you need the LCD display operating while you use JTAG to debug your code?
                            Some kind of demultiplexer hardware added maybe?
                              ajb2k3 @Thrasher
                              @thrasher The M5Stack is aimed at the beginners market and so JTAG is not required, Debug over usb or uart is all we need. JTAG is also a dying standard and getting dropped from alot of hardware. its only certain categories of hardware designers who make use of it now, basically enterprise companies.
                              S 1 Reply Last reply Reply Quote -1
                                Thrasher
                                  ajb2k3 @Thrasher
                                  @thrasher Raw micropython is available as standered as UIFlow is built on it. REPL is also available over USB.
                                  You can also Used VSCode and Xcode on OSX to program the M5Stack.
                                  @lukasmaximus89 made a good video on VScode on youtube.
                                  https://www.youtube.com/watch?v=Y9pOWgsNgKk
                                    Thrasher @ajb2k3
                                    • lukasmaximusL Offline
                                      lukasmaximus @Thrasher
                                      @thrasher I struggle to see how your webserver on ap question is in anyway related to jtag. I did already give you quite a lot of pointers to how to make a webserver on the M5Stack AP, please keep that to your other discussion instead of going off topic here.
                                        Thrasher @lukasmaximus
                                        @lukasmaximus
                                        Thanks, I've deleted all my posts, so if you have enough privelegies on this forum you can purge them
                                          repligon @ajb2k3
                                          @ajb2k3 Are you saying that m5stack has built-in full-fledged debug server that lets you put breakpoints and examine any variables or are you talking about debugging with printf? Because when I was looking for the infro on the first I couldn't find anything.
                                          ajb2k3A 1 Reply Last reply Reply Quote 2
                                            ajb2k3 @repligon
                                            @repligon said in Please allow jtag or jtag over usb on next version:
                                            REPL Explanation
                                            B 1 Reply Last reply Reply Quote -1
