    New Products 05-July 2019 And new video series.
    Anouncements
    9.2k
      New Products 05-July-2019 in Offical M5Stack Aliexpress store.
      After all this time, research and testing the MKV Camera is now available.
      MKV K210 AI Risc-V Camera
      alt text
      M5Stick-V RISC-V AI Camera
      General Description
      M5Stack recently launched the new AIOT(AI+IOT) Camera powered by Kendryte K210 -an edge computing system-on-chip(SoC) with dual-core 64bit RISC-V CPU and state-of-art neural network processor.
      M5stick-V AI Camera features its integration with machine vision capabilities, featuring the unprocessed acceptability to AI Visioning with high energy efficiency and low cost. We co-oped with Sipeed providing the MicroPython environment makes programming onM5stick-V easier.
      The module comes with the OmniVision OV7740 sensor, using the OmniPixel®3-HS technology, providing a best-in-class low light sensitivity, making it ideal for machine vision. In addition to an OV7740 sensor, M5stick-V features more hardware resources such as a speaker with built-in I2S Class-D DAC, MEMS Microphone, IPS screen, 6-axis IMU, 200mAh Li-po battery, and more.
      More than the visioning, M5stick-V also features the embedded APU - Audio Processor. With its hardware beam-forming support and dual 512-point FFT units, the M5stick-V is also capable of a series of machine hearing works like voice wake-up to speech recognition.
      Features:
      Dual-Core 64-bit RISC-V RV64IMAFDC (RV64GC) CPU / 400Mhz(Normal)
      Dual Independent Double Precision FPU
      8MiB 64bit width On-Chip SRAM
      Neural Network Processor(KPU) / 0.8Tops
      Field-Programmable IO Array (FPIOA)
      Dual hardware 512-point 16bit Complex FFT
      SPI, I2C, UART, I2S, RTC, PWM, Timer Support
      AES, SHA256 Accelerator
      Direct Memory Access Controller (DMAC)
      Micropython Support
      Firmware encryption support
      On-board Hardware resources:
      Flash: 16M.
      TFT: ST7789. 135*240 IPS 1.14 SPI
      Camera :OV7740
      PCM: MAX98357
      PMIC: AXP192
      Button: Front and side.
      Battery: 200mAh.
      Indicator light: RGBW .
      External storage: TF card/Micro SD
      Microphone: MSM261S4030HOR.
      Gyro: MPU6886.
      Interface: CONNEXT .
      A Laser Transmitter
      Laser TX](https://www.aliexpress.com/item/33054016613.html?storeId=3226069&spm=2114.12010611.8148356.37.480a25dcfKhGXl)
      alt text
      A Laser reciever.
      Laser RX
      alt text
      Mini Proto
      link text
      alt text
      ADC Hat
      ADC Hat
      alt text
      DAC Hat
      DAC Hat
      alt text
      RS485 Hat
      RS485 Hat
      alt text
      To accompany these new items, @lukasmaximus89 @lukasmaximus has now created a video.
      https://www.youtube.com/watch?v=el1corcD-to
      • world101W
        world101 @ajb2k3
        @m5stack
        No WiFi on the M5StickV.... why???
          One can only assume that its because the risc V doesn't have built in wifi.
