    ToF works from UI, not when using ampy
    Bug Report
    5.4k
    • H
      hkubota
      the ToF sample program does not work when running via ampy. But it works from the UIFlow.
      How to reproduce:
      • Connect a ToF sensor to the M5 stack (Firmware UIFlow 1.3.2)
      • Get the sample ToF program
      • Run via UI. Should work fine.
      • Copy&paste the Python code into a file named tof.py
      • Disconnect M5Stack
      • Run ampy reset to get the M5Stack into non-UIFlow (ampy v1.0.7 used)
      • Run ampy run tof.py
      You'll see that the distance is and stays 0
      • lukasmaximusL
        Hi @hkubota try running it from the micropython plugin in vscode. Video tutorial on how to get setup here https://www.youtube.com/watch?v=Y9pOWgsNgKk&t=73s
