    Adding external libraries via uiflow
    UIFlow
    9
    25
    94.4k
    • H
      hetzer
      I am trying to use BNO055 but cant add the library.
      Put the line import adafruit_bno055 inside an execute block but receive error. How can I add external libraries? Can anyone help?
        ajb2k3 @hetzer
        @hetzer this function is not presently available in uiflow blocky.
        You need to write the library to the m5 stack in a terminal onto the m5 stack before you call it using ampy from adafruit.
        • lukasmaximusL
          Seems ampy is not working in 1.3.1, I recommend firmware 1.2.2 or 1.2.3 if you want to transfer files via ampy you can check these two videos on our channel for getting started https://www.youtube.com/watch?v=rvP3GixWG1Y&t=109s and https://www.youtube.com/watch?v=V67MY-1ccqM
          • H
            hetzer @lukasmaximus
            @lukasmaximus I followed the instructions, copied the blynklib into flash/lib folder but receiving the following error:
            AttributeError("module object has no attribute Blynk",)
            • lukasmaximusL
              @ajb2k3 weren't you an world101 able to do some stuff with blynk. Have you tried putting the module on to the flash more than once? I've found ampy to be a little buggy at times, sometimes the copy wasn't successfull sometimes it was.
              ajb2k3A H 2 Replies Last reply Reply Quote 0
                ajb2k3 @lukasmaximus
                @lukasmaximus Yeh, @world101 had a lib working but I haven't had time to work with it in ages. been having issues with my in house server.
                • H
                  @lukasmaximus said in Adding external libraries via uiflow:
                  th blynk. Have you tried putting the module on to the flash more than once? I've found ampy to be a little buggy at times, sometimes the copy wasn't successful sometimes it was.
                  Yes, flashed it couple of times and also tried by transferring the file via upyLoader. Same result. Blynk is very easy to use and it would be great with the convenience of uiflow and M5stack.
                    I have tried looking into this today but having trouble getting repl to run. @hetzer I have not forgotten about your issue, I have just been too busy to look much into it.
                    • H
                      hetzer @ajb2k3
                      @ajb2k3 Thanks hope a built in block comes in the future
                      • R
                        romor001
                        Is there a tutorial somewhere on how to build the UI-Flow Firmware?
                        Would like to add some libraries, like for example paho-mqtt, and I think it would be best to build a custom FW for that.
                        https://github.com/EeeeBin/UIFlow-Firmware, referenced from https://github.com/m5stack/M5Stack-Firmware only offers binaries.
                        Not sure whether https://github.com/m5stack/M5Stack_MicroPython includes UI-Flow.
                        Any pointers?
                        • lukasmaximusL
                          As far as I know the Uiflow Micropython source is not available yet. Some others have posted guides on how to flash alternative micropython builds with other libraries https://www.hackster.io/andreas-motzek/execute-logo-on-m5stack-esp32-basic-with-micropython-3713fd
                          You could try creating your own spiffs image to include the libraries you need
                          https://github.com/igrr/mkspiffs although I haven't tried this yet and not sure if you have to add anything extra to make the uiflow firmware recognize the spiffs partition
                          • world101W
                            world101
                            Since m5stack moved from the Loboris fork of Micropython to the official Micropython v1.11 release, it seems the libs were also moved somewhere. With m5stack firmware v1.2.x, they used to be in /flash/lib, however now with firmware 1.3.x, that directory does not exist. If I try to create /flash/lib with ampy, the m5stack won't boot properly.
                            Internal FS (FatFS): Mounted on partition 'internalfs' [size: 2162688; Flash address: 0x1F0000]
                            Filesystem size: 2101248 B
                                       Used: 1400832 B
                                       Free: 700416 B
                              File "boot.py", line 4, in <module>
                              File "flowlib/uiflow.py", line 1, in <module>
                              File "flowlib/m5stack.py", line 5, in <module>
                            ImportError: no module named 'lib.speak'
                              File "main.py", line 17, in <module>
                            NameError: name 'rgb' isn't defined
                            MicroPython v1.11-112-g5f3c6ee93-dirty on 2019-06-26; ESP32 module with ESP32
                            The above serial output during bootup shows something in flowlib, but I can't seem to access it. If someone could assist with where to put the custom libs, I could probably get Blynk working again.
                            • H
                              heybin
                              UIFLOW most lib post in https://github.com/m5stack/UIFlow-Code, wiki have some api
                                ajb2k3 @world101
                                @world101 said in Adding external libraries via uiflow:
                                           Used: 1400832 B
                                           Free: 700416 B
                                I thought that was just me. I too tried to copy over blynk this weekend using vstudio but again had the same boot issue.
                                • world101W
                                  world101
                                  I just got Blynk working again with the latest 0.2.0 release from Github.
                                  git clone https://github.com/vshymanskyy/blynk-library-python.git
                                  cd blynk-library-python
                                  ampy -p /dev/tty.SLAB_USBtoUART -b 115200 mkdir /flash/blynk
                                  ampy -p /dev/tty.SLAB_USBtoUART -b 115200 put BlynkLib.py /flash/blynk/BlynkLib.py
                                  ampy -p /dev/tty.SLAB_USBtoUART -b 115200 get /flash/boot.py > boot.py
                                  Use vi to edit the first few lines of boot.py to look like this:
                                  import sys
                                  sys.path.append('flowlib/lib')
                                  sys.path.append('/flash/blynk')
                                  import machine, time, m5base, uiflow, BlynkLib
                                  Copy the modified boot.py back to the m5stack:
                                  ampy -p /dev/tty.SLAB_USBtoUART -b 115200 put boot.py /flash/boot.py
                                  Connect to the serial interface via screen and reboot the m5stack. You should see the Blynk lib load at bootup.
                                             Used: 1409024 B
                                             Free: 692224 B
                                  I (413) [TFTSPI]: attached display device, speed=8000000
                                  I (413) [TFTSPI]: bus uses native pins: false
                                  W (1296) sdspi_host: spi bus changed (1 -> 2)
                                  [ M5 ] init sd card Fail
                                  [ M5 ] node id:30aea449cd9c, api key:1CAA42CC
                                      ___  __          __
                                     / _ )/ /_ _____  / /__
                                    / _  / / // / _ \/  '_/
                                   /____/_/\_, /_//_/_/\_\
                                          /___/ for Python v0.2.0 (esp32)
                                  I (2284) modsocket: Initializing
                                  I (7288) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
                                  I (7392) phy: phy_version: 4100, 2a5dd04, Jan 23 2019, 21:00:07, 0, 0
                                  Reference thread: http://forum.m5stack.com/topic/575/blynk-on-m5stack-via-uiflow-and-block-maker
                                  • world101W
                                    world101
                                    By the way, you should be able to follow a similar procedure to load any custom library. Just create the directory /flash/custom and then reference it with sys.path.append('/flash/custom') in boot.py.
                                    ampy -p /dev/tty.SLAB_USBtoUART -b 115200 mkdir /flash/custom
                                    ampy -p /dev/tty.SLAB_USBtoUART -b 115200 put customLib.py /flash/custom/customLib.py
                                    in boot.py:
                                    import sys
                                    Then with uiFlow, you can use the execute block to have the choice when it gets imported (so you don't import it automatically when your program doesn't need it).
                                    • H
                                      hetzer @world101
                                      • A
                                        ATU
                                        Hello, world101 I am very new here in the forum and want to control my M5STACK with "blynk" via UIflow symbols.
                                        I use:
                                        UiFlow V1.4.3
                                        F5STACK fire, the red one.
                                        blynk for Python v0.2.1 (esp32_LoBo)
                                        MicroPython ESP32_LoBo_v3.2.24 - 2018-09-06 on M5Stack with ESP32
                                        I have successfully worked through all the above points.
                                        However, the dispaly from my M5STACK shows the following error message:
                                        error
                                        ImportError("no module named 'uiflow'",)
                                        I think that I have not installed the above mentioned elements:
                                        "machine, time, m5base, uiflow"
                                        In the boot.py I have edited the following, as you have described above:
                                        import sys
                                        I would like to implement remote monitoring via iphon of my groundwater pump.
                                        It would be nice if you could help me, please.
                                        • world101W
                                          world101 @ATU
                                          @atu said in Adding external libraries via uiflow:
                                          I use:
                                          UiFlow V1.4.3
                                          error
                                          import sys
                                          You’re not going to (easily) be able to use LoBo Micropython and the later versions of UIFlow. I think uiFlow v1.2.3 was the latest that LoBo was supported. Best thing would be to flash the official v1.4.4 firmware from M5Stack and use uiFlow v1.4.4.
                                          Try that first, then try to import the Blynk libs and see if it works.
                                          • A
                                            ATU
                                            Thank you, world101, for your quick response.
                                            Now Blynk works at my M5STACK.
                                            Your Blynk.m5b has five UiFlow blocks for only three virtual functions.
                                            But Blynk offers much more features.
                                            Has anyone already generated more UiFLOW blocks they can share?
