IoT M5Cam Project - problems porting code
Dear all,
I am trying to use a M5Cam as an IoT system. Long story short: I want to regularly take pictures, connect to a WiFi connection and upload them to a cloud service (in this case Google Cloud Storage, but any other sort of system would work). I found some github repo doing exactly what I need to do, but when trying to adapt it to my board, it crashes with the following error:
E (489) spiram: Expected 8192KiB chip but found 4096KiB chip. Bailing out..
I tried everything to force the board to recognise the 4Mb PSRAM:
ESP32-specific
CONFIG_ESP32_DEFAULT_CPU_FREQ_80=
CONFIG_ESP32_DEFAULT_CPU_FREQ_160=
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_SPIRAM_SUPPORT=ySPI RAM config
CONFIG_SPIRAM_BOOT_INIT=y
CONFIG_SPIRAM_IGNORE_NOTFOUND=
CONFIG_SPIRAM_USE_MEMMAP=
CONFIG_SPIRAM_USE_CAPS_ALLOC=y
CONFIG_SPIRAM_USE_MALLOC=
CONFIG_SPIRAM_TYPE_AUTO=y
CONFIG_SPIRAM_TYPE_ESPPSRAM32=
CONFIG_SPIRAM_TYPE_ESPPSRAM64=
CONFIG_SPIRAM_SIZE=-1
CONFIG_SPIRAM_SPEED_40M=
CONFIG_SPIRAM_SPEED_80M=y
CONFIG_SPIRAM_MEMTEST=y
CONFIG_SPIRAM_CACHE_WORKAROUND=y
CONFIG_SPIRAM_BANKSWITCH_ENABLE=y
CONFIG_SPIRAM_BANKSWITCH_RESERVE=8
CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST=
CONFIG_SPIRAM_ALLOW_BSS_SEG_EXTERNAL_MEMORY=Any ideas? I am a total noob with esp32 coding and so, but I would appreciate any help :) Also, if you happend to have some other example code I can take on, please share!
Original Code:
https://github.com/raphaelbs/esp32-cam-ai-thinker/tree/master/examples/google_storage -
please choose psram size to 4MB
Thanks @heybin ! That worked well (and it was surprisingly easy :) )
Now I gotta fix some new problems...
Stack smashing protect failure!
abort() was called at PC 0x400d645d on core 0
0x400d645d: __stack_chk_fail at /home/marta/esp/esp-idf/components/esp_common/src/stack_check.c:36Edit: Nevermind, i just needed to change the stack protection level from overall to normal. :)
Guess what? I hit another wall.
It seems the camera is giving trouble, despite me configuring the pins as here:
E (218) camera: Camera probe failed with error 0x20001
ESP_ERROR_CHECK failed: esp_err_t 0x20001 (ERROR) at 0x4008a228
0x4008a228: _esp_error_check_failed at /home/marta/esp/esp-idf/components/esp32/panic.c:721file: "/home/marta/Arduino/esp32-cam-ai-thinker/examples/google_storage/main/main.c" line 195
func: app_main
expression: esp_camera_init(&camera_config)config XCLK_FREQ int "XCLK Frequency" default "20000000" help The XCLK Frequency in Herz. menu "Pin Configuration" config D0 int "D0" default "32" config D1 int "D1" default "35" config D2 int "D2" default "34" config D3 int "D3" default "5" config D4 int "D4" default "39" config D5 int "D5" default "18" config D6 int "D6" default "36" config D7 int "D7" default "19" config XCLK int "XCLK" default "27" config PCLK int "PCLK" default "21" config VSYNC int "VSYNC" default "25" config HREF int "HREF" default "26" config SDA int "SDA" default "4" config SCL int "SCL" default "13" config RESET int "RESET" default "15" endmenu
