Can microSD card be accessed in UIFlow or with MicroPython?
I can not find any instruction in the documentation regarding how to access the tf card with python.
Can anyone help me? -
Take a look at the micro python official forums, there is a discussion about it
Not possible in uiflow yet. Micropython is easy
import os
os.mountsd()
os.listdir('/sd')etc...
@lukasmaximus
thank you for your reply.
But when I tried to exec os.mountsd I got an error as below.os.mountsd()
W (20141) sdspi_host: spi bus changed (1 -> 2)
E (20141) sdspi_host: spi bus 2 not available
E (20141) vfs_native: Failed to initialize SDcard (258).
OSError: [Errno 5] EIO -
@zhufu86 said in Can TF card be accessed in UIFlow or with MicroPython?:
@lukasmaximus
OSError: [Errno 5] EIOCan you post all you code please
I just exec in REPL.
import os
os.mountsd()nothing else....
I also tried os.SDMODE_4LINE, os.SDMODE_1LINE and os.SDMODE_SPI with os.sdconfig(...) before mountsd(), but none of them worked.
Forgot to say, I'm using M5Stack Fire.
import os
You also need the machine, sdcard and dpi library imported. That’s why I recommend that you visit MicroPython.org
thank you.
I went to MicroPython.org but found nothing helpful.
Finally, I erased the firmware and burned the M5S with the UIFlow-v1.3.1-Beta firmware.It worked, with the code below.
>>> import uos >>> uos.sdconfig(uos.SDMODE_SPI,clk=18,mosi=23,miso=19,cs=4) I (53596) gpio: GPIO[23]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull down: 0| Intr:0 I (53596) gpio: GPIO[19]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull down: 0| Intr:0 I (53604) gpio: GPIO[18]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pull down: 0| Intr:0 >>> uos.mountsd() W (65959) sdspi_host: spi bus changed (1 -> 2) I (65959) gpio: GPIO[4]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulld own: 0| Intr:0 --------------------- Mode: SPI Name: SU08G Type: SDHC/SDXC Speed: default speed (25 MHz) SPI speed: 40 MHz Size: 7580 MB CSD: ver=1, sector_size=512, capacity=15523840 read_bl_len=9 SCR: sd_spec=2, bus_width=5 >>>
Funny...
I re-burned back to UIFlow-v1.2.3, and it also worked.
>>> import uos >>> uos.sdconfig(uos.SDMODE_SPI,clk=18,mosi=23,miso=19,cs=4) >>> uos.mountsd() W (104277) sdspi_host: spi bus changed (1 -> 2) --------------------- Mode: SPI Name: SU08G Type: SDHC/SDXC Speed: default speed (25 MHz) SPI speed: 20 MHz Size: 7580 MB CSD: ver=1, sector_size=512, capacity=15523840 read_bl_len=9 SCR: sd_spec=2, bus_width=5 >>>
Here I attach the webpages which helps me mostly.
Hope it can help other people.https://github.com/loboris/MicroPython_ESP32_psRAM_LoBo/wiki/filesystems
https://forum.micropython.org/viewtopic.php?t=4551
https://loboris.eu/forum/showthread.php?tid=85 -
ok......
now even one simple uos.mountsd() also works...
good...>>> import uos >>> uos.mountsd() W (497494) sdspi_host: spi bus changed (1 -> 2) --------------------- Mode: SPI Name: SU08G Type: SDHC/SDXC Speed: default speed (25 MHz) SPI speed: 20 MHz Size: 7580 MB CSD: ver=1, sector_size=512, capacity=15523840 read_bl_len=9 SCR: sd_spec=2, bus_width=5
Yes, microSD cards can be accessed in UIFlow or with MicroPython. They allow you to read and write data from/to the microSD card, enabling storage and retrieval of information on compatible devices.
