    Failed to compile Linux_2.6.x_VCP_Driver_Source in Ubuntu
    Scheduled Pinned Locked Moved Lessons and Guides
    1 Posts 1 Posters 5.6k Views 1 Watching
    • L Offline
      lim
      I read the description of the environment it was modified CP210x driver for the 2.6.38 kernel (Ubuntu 11.04).However, I am now running Ubuntu 16.04, 4.13.0-35-generic.
      See the error messages below. Is this driver still needed to program/use M5Stack. If yes, has anyone succeeded compiling it?
      make[1]: Entering directory '/usr/src/linux-headers-4.13.0-35-generic'
      CC [M] /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.o
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:165:12: error: ‘usb_serial_probe’ undeclared here (not in a function)
      .probe = usb_serial_probe,
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:166:16: error: ‘usb_serial_disconnect’ undeclared here (not in a function)
      .disconnect = usb_serial_disconnect,
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:181:13: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
      .ioctl = cp210x_ioctl,
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:181:13: note: (near initialization for ‘cp210x_device.ioctl’)
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:184:16: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
      .tiocmget = cp210x_tiocmget,
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:184:16: note: (near initialization for ‘cp210x_device.tiocmget’)
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:185:15: error: initialization from incompatible pointer type [-Werror=incompatible-pointer-types]
      .tiocmset = cp210x_tiocmset,
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:185:15: note: (near initialization for ‘cp210x_device.tiocmset’)
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_get_config’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:321:3: error: implicit declaration of function ‘dbg’ [-Werror=implicit-function-declaration]
      dbg("%s - Unable to send config request, "
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_open’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:426:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      dbg("%s - port %d", func, port->number);
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_cleanup’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:459:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_close’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:472:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_get_termios’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:597:17: error: invalid type argument of ‘->’ (have ‘struct ktermios’)
      &tty->termios->c_cflag, &baud);
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_get_termios_port’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:619:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_set_termios’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:752:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:757:14: error: invalid type argument of ‘->’ (have ‘struct ktermios’)
      tty->termios->c_cflag &= ~CMSPAR;
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:758:22: error: invalid type argument of ‘->’ (have ‘struct ktermios’)
      cflag = tty->termios->c_cflag;
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_tiocmset_port’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:887:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_tiocmget’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:926:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_break_ctl’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:948:36: error: ‘struct usb_serial_port’ has no member named ‘number’
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘cp210x_init’:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:1013:11: error: implicit declaration of function ‘usb_serial_register’ [-Werror=implicit-function-declaration]
      retval = usb_serial_register(&cp210x_device);
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:1020:3: error: implicit declaration of function ‘usb_serial_deregister’ [-Werror=implicit-function-declaration]
      usb_serial_deregister(&cp210x_device);
      In file included from ./include/linux/module.h:18:0,
      from /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:21:
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c: In function ‘__check_debug’:
      ./include/linux/moduleparam.h:346:67: error: return from incompatible pointer type [-Werror=incompatible-pointer-types]
      static inline type __always_unused *_check##name(void) { return(p); }
      ./include/linux/moduleparam.h:398:35: note: in expansion of macro ‘__param_check’
      #define param_check_bool(name, p) _param_check(name, p, bool)
      ./include/linux/moduleparam.h:148:2: note: in expansion of macro ‘param_check_bool’
      param_check
      ##type(name, &(value));
      ./include/linux/moduleparam.h:128:2: note: in expansion of macro ‘module_param_named’
      module_param_named(name, name, type, perm)
      /home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.c:1043:1: note: in expansion of macro ‘module_param’
      module_param(debug, bool, S_IRUGO | S_IWUSR);
      cc1: some warnings being treated as errors
      scripts/Makefile.build:315: recipe for target '/home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.o' failed
      make[2]: *** [/home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source/cp210x.o] Error 1
      Makefile:1550: recipe for target 'module/home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source' failed
      make[1]: *** [module/home/esp32/Downloads/Linux_2.6.x_VCP_Driver_Source] Error 2
      make[1]: Leaving directory '/usr/src/linux-headers-4.13.0-35-generic'
      Makefile:4: recipe for target 'all' failed
      make: *** [all] Error 2
