    M5 burner not working on Macos X
    40 Posts 8 Posters 188.7k Views 4 Watching
      Alpine-Lake @ajb2k3
      @ajb2k3 Hi ! So how to make it work ?
      ajb2k3A A 2 Replies Last reply Reply Quote 0
        ajb2k3 @Alpine-Lake
        @alpine-lake I’m not in the office at the moment, has today’s version worked?
          Alpine-Lake @Alpine-Lake
          @alpine-lake Today's version ? They release one?
            @alpine-lake Forgive my ignorance but could you please tell me what thew API key is ? I asked tech support but didn't get an answer. Is this a code to unlock the software in order to make sure it is used with their M5 products ? Since I could never connect to a WiFi I was never able to get that "key" before erasing the module out of frustration and in an attempt to flash it anew. could this explain that to doesn't work ? Thank you.
              ajb2k3 @Alpine-Lake
              @alpine-lake the keys are generated on first boot by the device after a firmware update so no two keys are the same.
              A 3 Replies Last reply Reply Quote 0
                Alpine-Lake @ajb2k3
                  Alpine-Lake @ajb2k3
                  @ajb2k3 I assume it will be used in communications then ?
                    Alpine-Lake @ajb2k3
                    @ajb2k3 So if I am ever able to flash the firmware in the device a new API will be generated ?
                      ajb2k3 @Alpine-Lake
                      @alpine-lake Sorry I didn't finish the post before sending it as I was walking.
                      The Key is actually an Individual identity used for the server to communicate with specific devices.
                      From what I understand, when you access UIFlow the server queries a list of devices that has communicated with it. when the key you put into your session is read by the server it will send commands to the Devices matching.
                      Sorry If i'm not clear on this bit.
                      I am located in the UK.
                        ajb2k3 @Alpine-Lake
                        @alpine-lake said in M5 burner not working on Macos X:
                        Yes
                          Alpine-Lake @ajb2k3
                          @ajb2k3 Ok thank you. You are using the UI Flow IDE ?
                            ajb2k3 @Alpine-Lake
                            @alpine-lake yes, its all i can understand at the moment
                              Alpine-Lake @ajb2k3
                              @ajb2k3 You are referring to accessing the UI Flow web based correct ? I'm getting frustrated by the fact that the folks at M5 Stack can't point me in the right direction based on the symptoms I gave them.
                              Let me ask you this, normally everything can be done from the UI Flow interface right ? By that I mean that no other app or programs are needed to flash the firmware or the user's application ?
                                Alpine-Lake @ajb2k3
                                @ajb2k3 and it's working ? On a Mac ? You didn't have issues to make it run properly ?
                                  ajb2k3 @Alpine-Lake
                                  @alpine-lake new firmware not running on macosx but my java is way out of date.
                                    ajb2k3 @Alpine-Lake
                                    normally yes, but they had to rebuild the server and i think something broke.
                                      ok, i'm missing the react.js needed for the page to run.
                                        Alpine-Lake @ajb2k3
                                        @ajb2k3 I am trying to flash the M5 Stack with the UI Flow IDE, not the web based one. This is taking a lot of time. Is there any possibility to contact M5 development directly ?
                                          ajb2k3 @Alpine-Lake
                                          I'm also having trouble, it looks like the updater program is not working properly due to java.
                                          You can go direct to facebook page
                                            ajb2k3 @liushasha
                                            @liushasha said in M5 burner not working on Macos X:
                                            Please go to the official website and download the newest M5Burner 0_1558336217186_Screen Shot 2019-05-20 at 3.09.30 PM.png and keep the app file inside the folder.
                                            As alpine lake said, just show a blank white screen.
