    [Solved]My M5Go can't connect to flow.m5stack.com
    5 Posts 3 Posters 9.4k Views 1 Watching
    • W Offline
      watcharakorn
      I have updated my M5GO to UIFlow-v1.2.3 then I got a new API key and now it can't connect to flow.m5stack.com
      I tried to rewrite the firmware several times. But the problem persists. How do I fix it?
      • W Offline
        watcharakorn
        Now M5Go can connect to the flow.m5stack.com without doing anything. But I still can't connect with FlowUI
        • W Offline
          watcharakorn
          And now i can connect to M5Go with FlowUI by connecting to the internet without doing anything with my M5Go.
          I don't know what the cause of the problem is.
            if you can connect to m5flow you should be good to go.
            Once the correct SSID and password is put into the M5go once, it will stay there.
            how far do you get when you follow the connection guide in this document?
            https://github.com/Ajb2k3/UIFlowHandbook/blob/master/UIFlowhandbook.pdf
            • m5-docsM Offline
              m5-docs
              Server hangs
              M5Stack documentation URL
              https://docs.m5stack.com
