    [Solved]M5StickC I2C bus error
    UIFlow
    11.0k
    • C
      csqrd
      While using the M5StickC with the ENV "environment sensor" connected I receive the following error when running the ENV sample UICode program (https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Unit/ENV/UIFlo):
      >>> env0 = units.ENV(units.PORTA)
      File "m5flow/units.py", line 83, in init
      File "lib/bmp280.py", line 147, in init
      OSError: I2C bus error (6)
      I tried a second ENV sensor and received the same error. Any suggestions would be appreciated.
      • H
        heybin
        check if the grove port is in proper contact :)
        • C
          csqrd
          Thanks for the response. I replaced the grove cable with another grove cable and made sure it was fully seated and still got an error.
          >>> import units
          >>> a = units.E
          AttributeError: 'module' object has no attribute 'E'
          >>> a = units.ENV(units.P)
          AttributeError: 'module' object has no attribute 'P'
          >>> a = units.ENV(units.PORTA)
          Tried this as well:
          >>> from machine import I2C
          >>> i2c = I2C(freq=400000, sda=21, scl=22)
          >>> Traceback (most recent call last):
          File "boot.py", line 29, in reboot
          File "m5flow/hardware/axp192.py", line 96, in btnState
          File "m5flow/hardware/axp192.py", line 103, in _regChar
          >>> i2c.scan()
          [52, 81, 108]
          • H
            heybin
            It mean env init well, you can try a.temperature() and a.pressure() and a.humidity() to get msg
            • H
              heybin
              StickC grove IIC not 21, 22, it`s 32, 33
