    Continue to try Wifi Connection indefinitely, and go back to the connection/reboot if a try fails.
    36 Posts 5 Posters 166.6k Views 1 Watching
      ajb2k3 @Foxhound
      @foxhound Did you remember to change the ID code of the the M5go after flashing?
      UIFlow has been a bit buggy lately and several members have reported issue with connections dropping out between UIFlow and the M5stacks and M5Sticks..
      F 2 Replies Last reply Reply Quote 0
        Foxhound @ajb2k3
        Sorry mate, Change the ID code?
          Foxhound @ajb2k3
          I feel I am missing something. I have written most of my code using M5Cloud. I have two issues, the fonts won't change (I need larger text), and I need to modify the Wifi Setup so I can keep trying if it doesn't boot. I am using an M5 Stack Fire.
          I need to know which image I should be using (there seems to be a lot), and what is the best/proper way for me to put my code on it.
            ajb2k3 @Foxhound
            @foxhound the current firmware in 1.2.3 en for the M5Stack Fire.
            I wasn’t aware the M5Cloud still works.
            UIFlow is the current IDE and has a blocky and Micropython.
              Foxhound
              Interesting, mind throwing me a link to that firmware.
              FWIW, what I'm currently using, I setup Wifi and then get to here, where nothing happens (besides io.m5stack.com/#/<id> opening) when I scan it
              alt text
                ajb2k3 @Foxhound
                @foxhound on the computer or phone connect to the new M5Stack network and type in the address. This open a page on the M5Stacks internal micro server that allows you to set the M5Stack into station mode connected to your network. Select your network and insert the password and it should connect and restart disconnecting the M5Stack’s internal network. A new page should show up giving The M5Stack’s is code.
                In the UIFlow tutorial section is a link to my documents that have a guide to setup, there is an issue with enterprise networks
                  Foxhound @ajb2k3
                  Thanks mate, I've followed this; however this is where it lands me after I've connected it to a network (and it's disconnected the M5Stack's internal network). I never get the ID code. DO you have a link to the 1.2.3 firmware you mentioned?
                  I suspect there is an issue with the firmware I am using. I will look for your guide now. Have you got a link to it?
                  Thankyou so much for your help, I really appreciate it.
                    ajb2k3 @Foxhound
                    @foxhound https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/software/M5Burner_MacOS.zip
                    or
                    https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/software/M5Burner.zip
                    when the downloader fully fils the black circle, wait 20 seconds then press the red button on the m5 stack to reset it then press button C to access setup.
                    Strange that yours isn't showing the ID code as I've just updated mine and they worked properly.
                      Foxhound @ajb2k3
                      Thanks for this, it looks like in the link I can run the script to flash it using that flash.sh script, as I am on linux.
                      I couldn't find these this is really useful, thanks mate. I'll be home from my office soon to give it a go. Thanks.
                        ajb2k3 @Foxhound
                        @foxhound Did you get the connection Successful message when trying to connect?
                          Foxhound @ajb2k3
                          Woohoo!! Thanks so much mate, finally in and have placed my code into the UI Flow Python Editor and have started running it :)
                          Couple of questions related to my original question regarding wifi.
                          1. How do I permenantly save the code to my device. I can run it, but I when I reboot it doesn't boot into my code again.
                          2. Secondly, how on boot can I edit it so it automatically tries to reconnect if the Wifi isn't found.
                          Thanks so much for your help, really appreciate it.
                            ajb2k3 @Foxhound
                            @foxhound
                            In the top right hand corner is an icon with 3 horizontal lines, click on that then click on "Download" to permanently save to the M5Go.
                            I do believe that you use
                            import wifisetup
                            wifisetup.auto_connect()
                            at the beginning of the file above the
                            from m5stack import *
                            from m5ui import *
                            Alternatively, save the file as main.py and copy it to the M5Stack using ampy.
                              Foxhound @ajb2k3
                              Awesome, thanks, I'll give this a go.
                                Foxhound @ajb2k3
                                Okay awesome, thanks mate, have it working well now. Just need to make some modifications.
                                Auto connect seems to only work when called, and looks like it will throw an error if not connecting. I've found the code on the repo, so I'll modify that to continue trying when booting up if no wifi is found, and upon disconnection, call the function again.
                                Won't get much time to work on it for a little bit but will report back next week with my progress. Thanks very much for your assistance.
                                Also, download didn't work but ampy working really well now, thankyou!
                                  ajb2k3 @Foxhound
                                  @foxhound Glad to hear that I could help.
                                    Foxhound @ajb2k3
                                    Quick one, do you know where the source code for m5base is?
                                    ALso, with ampy, have you been able to get into directories past /flash.
                                    WHenever I try and list things inside say lib(/flash/lib), it say it isn't a directory?
                                    • lukasmaximusL Offline
                                        which micropython version are you using? if you did a custom flash not from the official m5stack burner you may have forgotten to flash the .spiffs file which contains all the folders and files you want to put on the filesystem
                                          Foxhound
                                          @lukasmaximus
                                          Hey Luke,
                                          thanks for getting back to me. I flashed with the flash.sh (I'm on linux) including all the .spiffs file.
                                          However, when I try to get I get the following.
                                            Strange, which version of the firmware are you using, could you post the log from flash.sh process or the command you used, maybe the files are not getting written to the correct memory addresses, usually it should look like this
                                            "--chip esp32 --port %port --baud %baud write_flash -z 0x1000 %PATH\bootloader.bin 0xf000 %PATH\phy_init_data.bin 0x10000 %PATH\MicroPython.bin 0x8000 %PATH\partitions_mpy.bin",
                                            "--chip esp32 --port %port --baud %baud --before default_reset --after no_reset write_flash -z --flash_freq 40m 0x170000 %PATH\spiffs_image_0x170000.img"
