    MQTT and Ui.Flow help needed
    UIFlow
    11
    24.4k
    • f3rn4nd0dF
      f3rn4nd0d
      Hi, this is my first test using UI.Flow and MQTT and I'm pretty stuck. Could you please take a look at this code and tell me what is wrong with it? Thanks!
      • H
        hetzer
        I had the same issue with io.adafruit.com but my code works with CloudMQTT.
        f3rn4nd0dF 1 Reply Last reply Reply Quote 0
        • f3rn4nd0dF
          f3rn4nd0d @hetzer
          @hetzer Thanks, but I need it to work with Adafruit io :(
          • world101W
            world101
            This one worked for me in the past. The username and active_key can be found on the "View AIO Key" link on io.adafruit.com. Make sure you have a feed named "light" set up under Feeds.
            • world101W
              world101 @f3rn4nd0d
              @f3rn4nd0d try changing the mqtt subscribe to username/feeds/parking but replace your username with the real one
              f3rn4nd0dF 1 Reply Last reply Reply Quote 1
              • f3rn4nd0dF
                f3rn4nd0d @world101
                @world101 It works! Thanks so much for your help!
                • world101W
                  world101 @f3rn4nd0d
                  @f3rn4nd0d
                  Great! Glad to help out.
                  • T
                    Techno86
                    Hello
                    I also have problems with Adafruit. I can't send temprature to my feed Temperature.
                    What is the difference between "set client ID" and "User" in UIFlow mqtt block ?
                    I join mt screeshot, maybe someone can tell me where is my mistake.
                    Thanks.
                    • f3rn4nd0dF
                      f3rn4nd0d @Techno86
                      @techno86 set Client ID is just a name for the client you are setting up. You can name it "client" (remove the quotes) if you want. User is your ID in Adafruit. Hope it is clear.
                      • T
                        Techno86
                        I made it working, i used "Client" in ClientID but there was also a problem of "/" in feed path.
                        I found issue in Python code.
                        Thank you for help.
                        • world101W
                          world101
                          In your picture, the “/“ looks strange (it is touching the text) and not like mine. Perhaps you copied and pasted the feeds path from the Adafruit dashboard into UIFlow and it added some other character that looks like “/“ but is not truly a forward slash. Not entirely sure, but glad you got it working.
