    M5StickC driver no work
    10 Posts 4 Posters 25.4k Views 1 Watching
    • KOsterOKK Offline
      KOsterOK
      M5Stack base - OK
      M5StickC - unknown device
        salty_good @KOsterOK
        @kosterok Hi, I am SHIO,
        M5StickC uses the FTDI's USB to Serial converter chip.
        It is usually no need to install a driver.
        Which OS (and version, distribution) do you use?
        Thank you.
        • KOsterOKK Offline
          KOsterOK
          I'm using windows 10.
          I think that maybe hardware bug because a few minutes after power up, the screen show me a strange things...!
            jpilarski
            Delete the driver and reconnect the board. Give it a few minutes and the proper driver should load and recognize your board.
            KOsterOKK 1 Reply Last reply Reply Quote 0
            • KOsterOKK Offline
              KOsterOK @jpilarski
              No work.
                @kosterok M5StickC displayed like this picture on my PC.
                Please check it again.
                That stop work problem is not hardware problem.
                Old version factory firmware have this problem.
                Please try to burn new FactoryTest example with Arduino IDE.
                (you need to install M5StickC library)
                thank you.
                • m5stackM Online
                  Hi
                  This is the error on software, LCD driver programmed inappropriately. This problem exist in the first batch of shipping. I apologize for our mistake. This is not the hardware problem, you can either rewrite the flash with the new factory test firmware which is available in our official Arduino repository, or with other code . For Arduino operation on stickC, you could follow the Tutorial video on official website.
                  Sorry again for your inconvenient.
                  • KOsterOKK Offline
                    KOsterOK @m5stack
                    @m5stack Thank you for your reply! I will do it as soon as I can install the driver. Can you help with this?
                    • m5stackM Online
                      The driver is already included in the factory test code, you need to setup the Arduino development firmware to upgrade to the newest
                      • KOsterOKK Offline
                        KOsterOK
                        I solved the problem. Manually installed drivers from here
                        https://www.ftdichip.com/Drivers/VCP.htm
