    M5Camera focus and lens
    PRODUCTS
    8.3k
    • R
      Rodion
      Hello
      Is it possible to adjust focus on the camera? The corresponding lesson on this forum says "don't try to adjust the focus or it will break" - but it makes no sense, this is a camera after all! The camera looks similar to the one from Raspberry Pi, no?
      Apart from fish eye, is it also possible to use other lens (with M12 mount adapter for example)? I need a narrow angle one.
      Thank you!
        ajb2k3 @Rodion
        @rodion
        Both camera's are fixed lens' not adjustable.
        If you have read the instruction for the Raspberry pi camera it also says not to adjust it.
        The close proximity of the lens to the sensor means that adjusting it will damage the lens or damage the fragile casing of the lens elements.
        • R
          Rodion @ajb2k3
          I would not agree about Pi camera. It has adjustable focus and they even sell a corresponding tool https://www.adafruit.com/product/3518
          Sorry, but a camera without focus is a just gadget, not an equipment...
          Another idea then, do you think those “smartphone lens” would work?
          https://www.amazon.com/Phone-Camera-Lens-KNGUVTH-Cell/dp/B07G73F3Y4/ref=mp_s_a_1_9?crid=1N2Z8PFQSVB1R
          Thank you
            ajb2k3 @Rodion
            @rodion said in M5Camera focus and lens:
            Thank you
            The older gen cameras were not adjustable and had a bad case of shattering. Looks like the Pifoundation found a cure for it.
            As to those lenses, I could not tell you as I lost mine!
            If you are willing to try then take lots of photo's document your finding and share them with the forums.
            • J
              jpilarski
              The fisheye lens can be focused but most likely the lens is positioned to it's optimal focus prior to shipping.
