    Where to find source code for the builtin firmware?
    7 Posts 5 Posters 16.4k Views 1 Watching
      joelhoro
      I got the ESP32Cam. The AP+webserver that streams videos works fine. Good news.
      On the other hand, the CameraWebServer does not. It all seems fine, I can see the webpage with all the video controls, but when I press on 'start streaming', nothing happens.
      I am fine working out how to fix this, but I'd need the source code for the firmware so I can double check the settings (mostly GPIO pins I guess) that make the built-in version work fine.
        heybin
        Here you can see the code and GPIO pins
        • m5-docsM Offline
          m5-docs @joelhoro
          Hello @joelhoro
          Here's the source code of "M5CamColorRecognition" for M5Camera (A Model). You can change the pin map for your ESP32CAM.
          https://github.com/m5stack/Applications-cam
          Factory firmware:
          The docs:
          M5Stack documentation URL
            joelhoro
            Found a way to figure it out. The diagram on https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram shows the GPIOs for the ESPCAM and apparently the D2 (pixel data Bit 0) is IO17 instead of IO32. Now the camerawebserver works (except for the LED not turning on but not a big deal).
              joelhoro @heybin
              @heybin / @watson
              wow you guys are so fast!
                PacoBlasco
                Where is the current firmware for ESP32CAM?
                https://github.com/m5stack/m5stack-cam-psram/tree/NoPsram is not available any more
                • m5stackM Offline
                  m5stack @PacoBlasco
                  @pacoblasco https://github.com/m5stack/m5stack-cam-psram
