    MAJOR BUG ! Connect to device broke
    27 Posts 8 Posters 105.3k Views 2 Watching
      ajb2k3 @patmolloy
      @watson I'm getting this disconnect issue with UIFlow1.2.0
      @watson 我正在使用UIFlow1.2.0解決這個斷開連接問題
        heybin @ajb2k3
        @ajb2k3 if sometimes internet not well,suggest try USB mode,it need download m5 offline webIde(only windows or linux)
          ajb2k3 @heybin
          @patmolloy looks to be working again.
            patmolloy @ajb2k3
            @ajb2k3 Thanks. I downgraded to 1.1.1 and this seems better. There are some scripts that I cannot get to work on 1.1.2 and 1.2.0 for now.In fact I just uploaded 10 or so times with no problems :)
              ajb2k3 @patmolloy
              @patmolloy
              I was on the Japanese FB group talking to Jimmy Lou this morning about it.
              • L Offline
                lelehel
                Ui flow doesn't work for me either. :( 1.2.2
                L ajb2k3A m5-docsM 3 Replies Last reply Reply Quote 0
                • L Offline
                  LastCaress @lelehel
                  @lelehel Can't connect either at the moment.
                    ajb2k3 @lelehel
                    @lelehel said in MAJOR BUG ! Connect to device broke:
                    @lastcaress said in MAJOR BUG ! Connect to device broke:
                    Have you tried resetting your internet explorer or trying a different web browser?
                    Something in M5Stack and UIFlows cookies was causing me issues.
                    • L Offline
                      LastCaress @ajb2k3
                      @ajb2k3 Yes, I tried other browsers, reboot and other m5stack devices - nothing works :\
                        se7enmilgram
                        I can confirm similar issues, just getting started for the first time. Green indicator on the device, "disconnected" status on the site. Multiple browsers, multiple operating systems, reset device.
                          I have just run a test from my end and I'm able to connect and program an M5stick and M5Go .
                          What firmware are you running @LastCaress and @se7enmilgram are you running on your devices?
                          Are you guys running the offline version or the version on flow.m5stack.com as the online version needs firmware 1.2.2 installed on your Sticks and stacks.
                            You need to reset your web browsers and delete all saved data and cookies connected to M5Stack.com and uiflow.m5stack.com.
                            Also deactivate content and add blockers for the above two sites.
                              se7enmilgram @ajb2k3
                              @ajb2k3 I only first burned the device yesterday, so it's running 1.2.2. I have a core devkit v1.0, off of amazon.
                              This morning, I woke up and gave it another shot without resetting the m5stack in a new tab on my browser, and it just worked. I'm guessing whatever is going on here is on the server side, only because I didn't do anything differently.
                                ajb2k3 @se7enmilgram
                                @se7enmilgram said in MAJOR BUG ! Connect to device broke:
                                Its strange because last night it was working for me and first thing this morning it was working as I'm working on my book today.
                                  @ajb2k3 I'll keep an eye on it and report back if the issue comes up again. I wonder if this was something related to a new device registration.
                                    It could be but it pops up every so often. I've even had it.
                                    • m5-docsM Offline
                                      m5-docs @lelehel
                                      @lelehel What's the specific phenomenon?
                                      @ajb2k3 Does your device work well?
                                      M5Stack documentation URL
                                      https://docs.m5stack.com
                                        heybin
                                        I am positioning this problem and it may take a while, because I don't know when this problem will reappear again. :D
                                        • E Offline
                                          edstar
                                          I am currently having the same issue.
                                          Tried everything recommended in this post and still happening on 2 of my units. Tried different firmwares, computers and browsers, disabled all ad blocking, cleared cookies and nothing helped. In my case it was actually working fine with http://flow.m5stack.com/beta/ with firmware 1.3.4 and then all of a sudden it wouldn't work. Seems like it is server side?
                                            heybin
                                            fixed
