    eFuse error with MicroPython firmware
    Micropython
    13.8k
    • A
      andrewm
      I'm following these instructions for setting up my M5Stack Fire for MicroPython:
      http://forum.m5stack.com/topic/67/micropython-on-webide-1-prepare-and-hello-world
      I have successfully erased the firmware and am attempting to burn m5cloud-20180516-v0.4.0.bin on the device. When I press 'Start', however, I see this in the logs:
      main.py:96: wxPyDeprecationWarning: Using deprecated class PySimpleApp.
      ('self.chip: ', 'ESP32')
      RF option applied...
      CONNECT BAUD: 115200
      .Efuse CONSOLE_DEBUG_DISABLE is already burned.
      Uploading stub...
      Running stub...
      Stub running...
      dl_list:
      ![Here's a screenshot of my settings in the Espressif firmware tool:
      ![0_1552304181844_esp32_burn.jpg]
      What can I do to get past this error and burn the new firmware to the device, please?
        That guide is out of date, if you install the UIFlow firmware they you have access to micro python via the UIFlow interface and via REPL
        • A
          andrewm
          Thanks for your quick reply. The link to the M5Burner executable for Windows - https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/software/M5Burner.zip - is dead. Is there another location to download this from, please?
          ajb2k3A m5-docsM 3 Replies Last reply Reply Quote 0
            ajb2k3 @andrewm
            @andrewm Check out this wip guide. you use the link in UIFlows settings.
            http://www.ajb2k3.co.uk/gettingstartedchapter.pdf
            • m5-docsM
              m5-docs @andrewm
              Hello @andrewm Have a try with this link.
              https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/software/M5Burner.rar
              M5Stack documentation URL
              https://docs.m5stack.com
              • m5-docsM
                m5-docs @andrewm
                @andrewm Now, the link (https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/software/M5Burner.zip) works.
                • A
                  andrewm
                  Thank you @ajb2k3 and @watson, I'm up and running now and appreciate your help.
